OEM Spring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-29-2009, 10:06 PM   #1 (permalink)
View itzsteven's Photo Gallery
3rd Generation OEM Spring?
I need to fix my dad suspension. I ordered KYB strut for him already. I wonder which spring should I buy for him. He doesn't want to lower the car. Is there anything close to the oem spring, or I have to order the OEM spring from toyota. He has 134k miles on his car already.
Saving money for Ripp Header!
itzsteven is offline   Reply With Quote
Old 08-29-2009, 10:35 PM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
You should not have a problem with using the used one you have on the car.
The problem is that all 4 have sunken over the years and miles, a new one wouldn't match the other three. So unless the spring itself is damaged or you are replacing all 4 corners, you should be okay with using the old spring.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 08-29-2009, 10:48 PM   #3 (permalink)
I will replace 4 corners, which springs should I buy?
Old 08-30-2009, 12:05 AM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
If he doesn't want it lowered, then you'll have to get a set of OEM springs. Any aftermarket spring would lower it. Fumes is right though. The springs have sagged a bit over the years, so if he's ok with the current ride height, you may be able to get a set of aftermarket springs with the least amount of drop. I think 1" is the smallest drop I've seen, and that's the most KYB's will handle anyway.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 08-30-2009, 07:50 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
if you want your cake and to eat it too. try to order some gen3(92-96) SE springs. same ride hight but stiffer. if your tryin to save money on them though then the eibachs may be a good choice if hes ok with a fairly stiff ride. they dont drop much.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 08-30-2009, 08:19 AM   #6 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
Tien H-Tech springs won't lower it much either, the specs for lowering are ~0.9" front and ~0.1" rear. But they're pretty expensive compared to other brands.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 08-30-2009, 09:28 AM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
According to various online catalogs. The sedan/coupe/wagon all use the same rear struts and therefore they can use the two different version of springs. (check to verify)
Looks like the wagon springs are the stronger version. So you may be able to order Raybestos or Moog springs from rockauto.com (if you don't want to buy them from the dealer).
You may want to consider changing out the rubber parts as well. Are the mounts working ok?
Rockauto's catalog suggests the Raybestos fronts are $73 a pair (?) and rears $86 plus shipping.
Front:
http://www.rockauto.com/catalog/moreinfo.php?pk=1028986
Rear:
http://www.rockauto.com/catalog/moreinfo.php?pk=1028855
Old 08-30-2009, 09:42 AM   #8 (permalink)
View m52go's Photo Gallery
would gen4 springs work on a gen3 ? i have some for sale from a gen4
m52go is offline   Reply With Quote
Old 08-30-2009, 10:08 PM   #9 (permalink)
Will the KYB + H&R OE sport springs give the car a handling like a Gen 6 SE? If it is, my dad will be okay with it, he didn't have a problem when driving my 08 se. I hope that 1" drop won't give him that much trouble when driving in the snow. Also, I visual checked the springs today, they're in good condition. I didn't see rust but not sure about sagging, I couldn't tell from the visual check. For 134k miles, would they be okay to be re-used?
Old 08-30-2009, 11:38 PM   #10 (permalink)
uibalnme's Avatar
I've got KYB's and original springs with 146K on them. I have no problems with handling. Then again I also have a Whiteline RSB, and Whiteline strut bar.
Old 08-31-2009, 12:04 AM   #11 (permalink)
Thanks Uibalnme, I will go ahead use the original spring then. I will get him a ebay strut bar.
