After a bit of procrastinating I finally completed it.
It's pretty simple, it's an OE Camry grille cut up and some mesh siliconed in behind it. I painted the mesh flat black with two coats of clear. The grille was originally chrome. I scuffed it down with a green Scotch Brite pad to remove the glossy finish, then two coats of primer, 4 coats of flat black and three coats of clear. I think it looks pretty good IMHO.
At first when I installed the finished grille you could see the horn, condenser and other components behind it, I went and gave it a quick coat of rattle can black now it looks nice and clean behind the grille.
Let me know what you guys think. Pu next are some JDM style amber corners.
