2001 Camry LE, 4 cyl. - What to watch out for ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2009, 11:33 AM   #1 (permalink)
View Brad1's Photo Gallery
Going to look at an '01 Camry LE after work. This car has the 4 cyl engine. It only has 37k miles on it.
What are the most common mechanical problems that occur with this year / motor Camry?
Thanks in advance.
Brad1 is offline   Reply With Quote
Old 09-06-2009, 02:43 AM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $862710
View BamZipPow's Photo Gallery
Not sure if you could tell if the engine is starting to sludge up or not.
Check the motor mounts fer wear and tear. They shouldn't be bad with only 37,000 miles on them but you never know and it only takes a few seconds to check.
Check fer the common things like oil leaks/drips. See if the fluids have been changed lately. I'm gonna guess the PS, brake, coolant, and trans fluids haven't ever been changed on it.
Check that radiator over carefully fer microcracks...the plastic tanks will eventually fail.
BamZipPow is online now   Reply With Quote
Old 09-06-2009, 11:36 AM   #3 (permalink)
werkit217's Avatar
View werkit217's Photo Gallery
37K miles...honestly the only thing you need to watch for is another car crashing into you
I build cars the way I build them, anybody who thinks any different, well... they're just wrong
werkit217 is offline   Reply With Quote
Old 09-06-2009, 12:12 PM   #4 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
The only major problem with buying a used 2001 Camry (5sfe I4 engine) is engine sludge. If they have records of regular oil changes then it's safe to assume there is no sludge build up. With low mileage as that, it's even less likely there will be sludge build up.
Aside from that and being a low mileage car, it'll be a long time before any major maintenance needs to be done.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 09-06-2009, 03:32 PM   #5 (permalink)
View Kingdom934's Photo Gallery
Thats pretty low mileage.
Again...sludge. A lot of 5SFE suffered from this fate. Give a quick check under the oil cap. Do you see metal or some blacken like charcoal stuff? It's not a 100% indicator, but it gives an ideal how well the oil been change.
Otherwise then that besides the valve cover leaking oil issue, that's pretty much it. My mom has a 2001 I4 LE camry with about 85K already and she's had no issues with it so far. Just took care of typical maintance (i.e. belts, water pump, spark plugs, etc, etc)
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 09-06-2009, 08:32 PM   #6 (permalink)
Diablo
View GaviN's Photo Gallery
My aunt has a 2000 or 2001 Camry with 173k miles. The only problems she has had out of it since owning it brand new has been an electrical issue with the brake lights and a sensor which tripped the check engine light, both issues happened within the past 6 months, thats about it. Excellent car. She actually just sold it to my aunt for $1500 and she picked up a 2010 LE-V6 Camry this past Thursday. Car drives smooth as butter!
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
