Can you be certain that it's the water pump and not some other cooling system issues (thermostat, radiator, radiator cap, fan, or even head gasket)?
In general, when you replace the pump you also do the timing belt, and vice versa.
You should be able to get a "complete" timing job that includes the water pump at a competent independent shop for $500-600? Which should include the following parts. But first you need to make sure it's indeed the water pump.
(older
www.rockauto.com prices for 3/5SFE)
GATES TCK199 (kit of timing belt with two pulleys and instruction)
$84.79
GATES Part # K030295 PS belt $4.32
GATES Part # K050435 Alt/AC $12.12
FEL-PRO TCS45641 Cam seal $4.11
FEL-PRO TCS45920 Crank seal $6.04
BCA Part # 221820 Oil pump seal $2.71
AISIN (Toyota #16110-79185) water pump $58.79
FEL-PRO VS50304R valve cover gasket set $13.94
Originally Posted by BadYanish
I have a 1998 Camry LE 4cyl. It started running hot and I'm being told that the problem is the water pump. They quoted me a $1,300 repair (I think I could get it done for $800). This car has almost 150,000 miles on it. My question is, should I get the repair or invest in a new, used car? This Camry has never had any major issues. I don't want to throw good money after bad but investing in a new car would make my monthly budget pretty tight. I look forward to your opinion. I just don't know how much more time I can expect out of this vehicle.
