hi there,
i've been fighting with low idling revs on driving gears for some time now. by now i can say i did all it takes to fix 'em (spark plugs, wireset, fuel filter, alt&p/s belts, pcv valve, cleaned TB). i no longer have the problem on Parking and Neutral gear which is good, but for some reason issue still occurs on all driving gears (D, R, 1, L) at full stop.
it feels like car becomes shaky and loose/untightened parts start shaking (visibly) and i can hear some (plastic?) vibrating noise (not loud) coming from front of car. quite annoying it is, especially at stop lights ...
is it transmission related then?
also just discovered by double-checking repair bills that tranny was never flushed in this car (my old ride was, not this one) and it has currently almost 65K - i know my forum sig says 66k, just ignore it
current symptoms:
a) non-driving gears P & N
idling engine revs close to 4th bar on gauge (800rpms) or sometimes in middle between 3rd & 4th (750rpms) but that seems tobe caused by A/C running - all perfect to my taste
b) driving gears D & R and also 1 & L
idling engine revs close to 3rd bar on gauge (600rpms) or sometimes slightly above it (~650rpms) - visible shaking of loose items in car, can hear vibrating noise coming (i think) from front of car - there is no loose parts over there, double checked it!
shall i flush tranny then? will it fix it?
thanks for opinions people. this seems to be the last car annoyance i got... hopefully non-disastrous
anybody knows how much the dealer charges for transmission flush? local shops can do it at around $80-120+tax, but i'd prefer the dealer to get his done (and use their fluid).
also i was thinking about bringing car to dealer (first time in history of this car) and running diagnostics on computer. perhaps they can adjust the idling revs somehow through the computer software update or so. need to dig it up.
found similar case of Opel/Vauxhall Astra in UK that got fixed in dealership by adjusting idling revs. may try this out:
http://www.astraownersclub.com/vb/sh...t=12786&page=2
