95 2.2 Transmission question
I've searched. But can't find the symptoms i have. At highway speed trans just what i can only describe as slipped or disengaged. the speedo and tach both increased ,but it felt like i was in neutral.it lasted only a few second and ran fine for about 10 miles at between 35 and 60mph. the fluid is clear and smells good. It was changed about 10K ago (drained and refilled with new strainer)No CEL,No OD lights.
I know the fliud should be changed a couple of times to replace most of it. It has 155,000 on it. This morning I went less than a mile and it happened again,So i put in the next gear down it engaged and when i put it back in drive and it drove fine.
Should I try to change fluid and clean pan,check connections ETC.Any suggestions ?
