Front left squeeling - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2009, 10:25 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
It's coming from my tire. I just had new tires put on but haven't had the alignment set yet. It's not a brake squeal, I've heard what that sounds like. My brakes are almost new anyhow.
It only happens when the car has been sitting for a while and the engine is cold.
Ideas?
Edit: Doesn't matter if I'm on the brake or not. It's sporadic.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-02-2009, 11:23 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
When you say on or off the brakes, do you mean the car is still moving, right?
If you rotate the tires, does the noise move sides? That would be a good tell.
Ideas?
Old 09-02-2009, 11:56 PM   #3 (permalink)
Slowly learning....
The car is moving, yes. Whether I'm coasting in neutral or braking, it doesn't make a difference.
I'll rotate the tires tomorrow and see if it makes any difference.
