I did mine from the top. Mine is a V6. Recommend if you have a V6, to pull your glovebox, and disconnect the engine wiring harness from under the dash (4 plugs, if I remember right) and pull that through the firewall. (Really easy) If you can do the same with the donor car, you will be even more time and effort way ahead. The yard I got my engine from didn't do that, and I spent at least 2 hours transfering my harness to the new motor. And believe me, it is much easier with the motor out of the car. If you are splitting the motor and transaxle, the drive axle tends to seize in the motor mount/axle carrier. Disconnect that from the motor and frame, and pull the axle out in one piece. Some bolts will be easier to work with when the engine is raised. Power steering pump comes to mind here.
