Headlight problem 1995 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2009, 03:37 PM   #1 (permalink)
View fishnow's Photo Gallery
3rd Generation Headlight problem 1995 Camry
Hi All, The problem consists of, I have low beam lights and all turn signals. When I turn on the high beams they won't come on. The high beam flash works fine. When the dimmer switch is on high I have voltage at the plug to the lights, but no ground. I checked both grounds of both lamps back to the plug in for the dimmer switch all good. The ground feeding the dimmer switch white and black wire is also good. I checked my dimmer switch according to Toyota Service manual high beams contacts have 300 ohms across them, low beams has zero, could this be a problem, does any one know if this could be the cause of the problem?? Thanks for any help I also checked the intergration relay all good according to manual
fishnow is offline   Reply With Quote
Old 09-07-2009, 07:31 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
do you have voltage to the bulbs?
Old 09-11-2009, 10:02 AM   #3 (permalink)
Headlite problem
Yes I do have voltage on one of each pins on each lite recep. The other pins which are the grounds are not there, I can jump those pins to ground and both side come on. All grounds feeding light switch are good, was figuring on a bad dimmer switch?? needed some input from other toyota owners. Thanks for responding
Old 09-11-2009, 10:18 AM   #4 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Since the high beam flash (pull stick towards you) is working i'd think thats it's a problem in the switch in the steering column. I'd pull it apart and check it out. Theres a bunch of phillips head screws underneath it that hold it on....easy removal. and
'07 Honda Ruckus Big Bore
Old 09-12-2009, 02:08 PM   #5 (permalink)
Headlight problem
Thanks for responding , I have to agree with you, as many checks that I have made I feel it is the dimmer switch. It does not hurt to get a second opinion. I made a recent mistake and paid for the services of just answer for toyota the guy told me to check the wrong wire on a toyota truck speedo problem, I went and bought the sensor 125.00 it did not fix it I found the problem and fixed it myself. I will order the switch and install it, Thanks again
Old 09-12-2009, 04:02 PM   #6 (permalink)
Freakin Scooters
i'd check local junk yards first! save yourself A LOT. of I might be able to find one in a junk yard here for you.
Old 09-13-2009, 11:38 AM   #7 (permalink)
headlight problem
Hi Lynchburg, we have a couple of fair salvage yards here Decatur IL, if they don't produce I will contact you, Thanks for the offer
