5sfe manual trans not going into gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 12:41 AM   #1 (permalink)
cardomain.com baggedcamry
BAGGEDCAMRY01's Avatar
View BAGGEDCAMRY01's Photo Gallery
3rd Generation 5sfe manual trans not going into gear
ok people. i know i havent been on here for a long time.
is their anyone had this problem? when coming to a stop the car wont go into 1st, 2. 3. 4. 5 u have to slam the shifter into gear. when i got home checked my fluids. everything is good. i turned the car while its in gear the car didnt go forward. so i dont know if this would be clutch issue? and also when the car is off. i try to put it in gear without the clutch it still wont go in or pressing on the clutch.
BAGGEDCAMRY01 is offline   Reply With Quote
Old 09-07-2009, 02:53 AM   #2 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
If it doesn't go into gear, how do you drive it?
Maybe:
1) The shifter cables are sticking
2) You've bent or damaged the gear change levers
3)Faulty clutch or clutch release mechanism
4)Synchro rings damaged or worn
5)Synchro spring installed incorrectly
6)Synchro sleeves damaged
7)Worn or damaged selector fork
8)Excessive end float in the input or output shaft.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
Old 09-07-2009, 10:50 AM   #3 (permalink)
well, i have to really force it hard to get into that gear. now the car is parked. i dont want anymore damage
Old 09-07-2009, 02:26 PM   #4 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Guess what? Your Camry's fuckin sweet
Where in Cali are you?
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 09-07-2009, 08:19 PM   #5 (permalink)
thanks man. i leave in san bernardino county. mentone, ca 92359
Old 09-08-2009, 12:53 PM   #6 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
Maybe:
since he says he can't get it into a gear even w/ the engine off, that eliminates the syncros part. also mostly eliminates the clutch as the problem.
also check into the shift bushings on both ends of the cables. if they're gone, the shifter will behave really weird.
baggedcam - when you were last driving it, the clutch DID disengage when you hit the pedal, right? any grinding noises or anything when trying to put it in gear when it's running?
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 09-11-2009, 09:45 PM   #7 (permalink)
no there wasnt any grinding noise or anything. yea when i pressed the clutch in the shifter wouldnt go in. once i did get into gear it didnt pop out or anything. u had to use all ur muscle to get the damn thing in.
