No power to power window? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 11:45 AM   #1 (permalink)
View felpz123's Photo Gallery
my window regulator went out a while ago, but the motor worked fine. 2 weeks later, i am not even receiving any power to cable.
is this most likely a fuse? does anyone know where its located? thanks
94 4 cyl
felpz123 is offline   Reply With Quote
Old 09-07-2009, 05:22 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i would just get a new regulator for starters...
i got cheapy ones from ebay almost 5 years now... those ebay regulators has not failed me yet
as for the fuse, you have to get a 10mm socket and remove the panel just below the steering wheel (should be four nuts) theres 2 plastic covers covering two nuts use a flat screwdriver to remove the cover...
and once you have it removed just above the fuse box ON the fuse box there should be a green and pink large fuse.. cant remember which one is for the windows tho....
there is DIY on window regulators on here... just search
