5fse + valve cover ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 12:40 PM   #1 (permalink)
View dcninja757's Photo Gallery
How do you remove the valve cover so you can replace the valve cover gasket. Mine has a leak in the rear of it so I'm trying to replace that, and I wanna paint it while it's off. I don't see any bolts on it though like on my previous cars, maybe I'm just slow. Any idea where they're hiding, and is it complicated to remove on our cars?
dcninja757 is offline   Reply With Quote
Old 09-07-2009, 12:47 PM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
not really, pull the spark plugs and there are four bolts that hold the valve cover down...you might nned an adjustable wrench to get the bolts loose
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 09-07-2009, 12:56 PM   #3 (permalink)
yea but i cant find the bolts! lol I know it sounds silly but I dont see them!
Old 09-07-2009, 01:23 PM   #4 (permalink)
D.I.Y.'er since 2004
DxElite's Avatar
Gameroom cash: $259191
View DxElite's Photo Gallery
They're nuts, not bolts, they screw onto the spark plug tubes.
I bought a large socket to take them off and properly torque them afterward.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline   Reply With Quote
Old 09-07-2009, 01:40 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
they are huge nuts - something like 30 mm in size. they are covered by the top of the park plug wires.
Old 09-07-2009, 02:02 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yes, those huge nuts under the plug boot covers.
You need to retorque them after 30 minutes on there. Use small dabs of RTV on the semicircular plug cutouts on the cylinder head. Don't let the old RTV fall into the head.
Old 09-07-2009, 05:55 PM   #7 (permalink)
Gameroom cash: $303255
30MM is correct for those nuts. Get a 30MM socket and a torque wrench. The correct torque is 17 ft lbs. I would torque them down in 3 even passes of 6, then 12 and then 17 ft lbs, sitching from nut to nut to insure even tightening.
Mike
Mike Gerber is online now   Reply With Quote
Old 09-07-2009, 09:05 PM   #8 (permalink)
so they're inside the spark plug holes?
Old 09-07-2009, 09:22 PM   #9 (permalink)
Creeps228's Avatar
bolts nuts whatever they are called...its just four of them
MR2: 7A-GE
Old 09-07-2009, 09:25 PM   #10 (permalink)
DxElite's Avatar
No, there right on the top under the square spark plug boots. The tube is threaded on the top and you'll see large and flat nuts.
Old 09-07-2009, 10:19 PM   #11 (permalink)
oh ok thanks. changed my spark plugs a few weeks ago, must not have noticed.
Old 09-09-2009, 10:12 AM   #12 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Re-check the torque in a week.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 09-09-2009, 01:29 PM   #13 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
besides the 4 nuts on top (That are 30mm, so either get a 30mm socket like i did or just use channel locks), there are 2 10mm bolts if i recall ... most of us use RedPhoenix's DIY Guide for painting the valve cover:
How-To Guide: Removing and Painting a Valve Cover - 5SFE -- 56K warned Lots of Pics
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 09-09-2009, 09:40 PM   #14 (permalink)
+1.
Should also do the first retorque after 30 minutes.
Old 09-10-2009, 01:11 AM   #15 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
Bottom of the page:
3sfe spark plug tube oil leaks
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
