What the hell happened?! Please help!
Ok, so I decided to replace my rear valve cover gasket since it was starting to leak. So I pull the upper manifold, ok no problems there, then I get the valve cover off, ok no problems there, I get the valve cover back on, no real problems there just a bit of maneuvering to get it on, put everything back together, then I go to start the car. After about 1 minute I notice a big stream of oil coming out from under the car!! What the hell!! I shut the car off right away.
Now am I supposed to RTV in any spots, like the corners? Could the gasket have been pinched or rolled when it went back in? I made sure I cleaned the cover and the mating surface before anything. What am I missing? Please help!
Thanks in advance!
Originally Posted by Venom_5
"honey, i bought you this Recaro passenger seat to sit in my Camry - will you marry me?"
