i replaced my brake pads and rotors over a year ago on my 99 v6 and theyve squeaked on and off ever since. ive had to take it back apart atleast 4x and wiped down the rotor with brake parts cleaner and scuffed up the pads with 600grit to get rid of the glazing but sure enough it will start squeaking again a few days later. i also grease up the friction points on the tabs that the pads have.
the strange thing is that they tend to squeak when i first drive the car after its been sitting a while and tends to get less severe or stop altogether after a bit of driving.
i cant think of what else to do besides buying new pads but i figure if im gonna do that i might as well replace the caliper with something better, like the 2-piston caliper from an es300.
so my question is what other troubleshooting can i do before i just tear out the caliper and pads and upgrade them?
part 2 to my post is that i put h&r springs on my car (with the factory struts) for about a 1.4" drop in the front and 1.3" in the rear and i get an alignment done atleast once a year but i still get excessive wear on the inside of the front tires. ive read that anything less than 1.8 or 2" doesnt really require a camber kit but i figure i might as well get one but dont know if theres a difference in quality between a cheap $20 ebay (
http://cgi.ebay.com/ebaymotors/AVALO...#ht_1183wt_967
) camber it or the $50 H&R Triple C (
http://www.horsepowerfreaks.com/View...iple_C_-_Front). i feel more comfortable getting the H&R kit.
Thanks in advance for your suggestions.
