Fog lights help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-07-2009, 07:47 PM   #1 (permalink)
Gameroom cash: $160210
View FLIP K1DD's Photo Gallery
Question Fog lights help
so instead of wiring them to your battery and using a relay or inline fuse or switch, can you just wire the positive to positive and negative to negative on your headlights? that way the wiring is much easier and all you need to do is possibly get a stronger fuse for the head lights? or will this cause problems?
FLIP K1DD is offline   Reply With Quote
Old 09-07-2009, 08:23 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Don't ever replace a fuse with a fuse of a higher current rating. The manufacturer selects the fuse rating to protect the wire by preventing too much current from running through it. If you run the fog lights off of the headlight circuit and put a larger fuse in, you run the chance of over loading the wires and causing them to melt down, and possibly catch fire.
So, to answer your question, no.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 09-08-2009, 04:10 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
just wire them to the battery and use the parking lights as a switch. or pm asg14...he will tell you a better way to wire them then toyota could have done.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
