Gen 3 and 4 Rear Drum to Disc DIY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2009, 10:31 PM   #1 (permalink)
Gameroom cash: $924200
iTrader Score: 13 reviews
View ASG14's Photo Gallery
1: Take off wheel.
2: Spray PB Blaster (Or similar penetrator) onto the brake hose.
3: Remove Drum. If they are rusted on, use a screw in the holes on the drum to pop it off the hub.
4. Unscrew the bolt that holds on the brake hose to the strut. (12mm)
5: Unscrew the E-Brake cables. (All are 10mm)
5A: Bolt in side rail.
5B: Bolt in middle after the bend of the cable.
5C: Unscrew the 3 nuts that hold on the heat shield, in order to access the rest of the cable.
5D: Unscrew the E-brake cables that are under the heat shield.
5E: Take the cable out of the holder. There is a hole on the top part, so that when you turn the cable 90 degree’s, it can be pushed up and taken out.
6: Loosen the brake hose, and retighten. This is just to break it loose to make it much easier in the following steps.
7: Remove the Hub. 4 bolts. (14mm)
8: Pull the backing plate off, and let it sit there.
9: Slid the backing plate back onto the knuckle. Make sure to put the big O-ring back on, to keep crap out of the hub bearings.
10: Screw back on the hub. (59 ft/lbs)
11: Set the E-brake adjustment to minimum.
12: Put on the rotor, and tighten the Caliper Bracket. (34 ft/lbs)
13: Put on the caliper and tighten the bolt. (14 ft/lbs)
14: Screw on the new brake hose onto the caliper. Make sure to use 2 new copper washers as shown. (21 ft/lbs)
15: SLIGHTLY loosen the old brake hose. Then pull out the clip that holds it onto the car. Then unscrew the old brake hose, and screw on the new one.
16: Screw back on the new E-brake cables and heat shield by following step 5 in reverse order.
17: BLEED THE DAMN BRAKES PLEASE!
5 Lug Corolla WHAT?
The Following User Says Thank You to ASG14 For This Useful Post:
evo_camry (04-23-2012)
Old 09-09-2009, 11:07 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
added to sticky!
HaHa
Old 09-09-2009, 11:49 PM   #3 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426353
View EEngineer's Photo Gallery
awesome stuff
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is online now   Reply With Quote
Old 09-09-2009, 11:58 PM   #4 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
nice one adam!
RU2CHKN is offline   Reply With Quote
Old 09-09-2009, 11:59 PM   #5 (permalink)
View Camry LE 94's Photo Gallery
3rd Generation
awesome... thanks for the useful info. since the stock Gen 3/4 Camrys come with drum brakes, what specific rotors do you get in order to convert the drums to discs? does Toyota make rear discs just to replace the rear drums?
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 09-10-2009, 12:06 AM   #6 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Autozone carries a rear rotor for our cars, I'm sure most other car part stores do also.
Clicky
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-10-2009, 01:34 PM   #7 (permalink)
View FireFire's Photo Gallery
awesome....
great job... But where did you connect to the hand brake cable?
FireFire is offline   Reply With Quote
Old 09-10-2009, 03:24 PM   #8 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
oh look....it's my camry, thanks again adam!
i believe they connect back to the same location...
'07 Honda Ruckus Big Bore
Old 09-10-2009, 04:31 PM   #9 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
My mind isn't catching the full view of the hand brake. How does that work?
#2! is offline   Reply With Quote
Old 09-10-2009, 04:35 PM   #10 (permalink)
You pull up the handle and the cable tightens the shoes
5 Lug Corolla WHAT?
Old 09-10-2009, 04:35 PM   #11 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
A lot simpler than I thought!
How long did the process take for a pro like adam?
I can times his time by double or triple, to get my est swap time
and about how much to spend?
and what kind of calipers/rotors are those? ha
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 09-10-2009, 04:40 PM   #12 (permalink)
ES300 calipers, reman. I sold a couple swaps for it actually. Mostly on SolaraGuy since everyone here who said they would buy a kit f'ed me over.
If you have NEVER done it before, BUT know how to work on car's, I say give yourself 5 hours to be safe. More if in a state with rust.
As for cost, all depends what you want to use. New, reman, all used, combo of new/used/reman.
5 Lug Corolla WHAT?
Old 09-10-2009, 04:45 PM   #13 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Those calipers/rotors are nice, but HUGE!
I was thinking of just going with v6 rear disc setup to minimize cost, etc. Not too much rust in Cali, but 5 hours isn't too bad at all. Just need to set a good day aside or something when I decide to do it all.
Anyway, good DIY, this will be extremeley helpful when I get to it
ACCIDENT...
Thanks
Old 09-10-2009, 04:47 PM   #14 (permalink)
#2!
Aw so your leaving the shoes on and they press against the inside of the rotor? Is this how its normally done with stock rear discs? Iv only seen up close GM rear discs with the pump engage.
Old 09-10-2009, 04:57 PM   #15 (permalink)
JC, the Camry rear setup is the same steps. There isn't a price difference between the ES300 and Camry setup actually. Also, the I4 and V6 had the same rear disc brakes. The V6 wagon and ES300 had the bigger ones.
#2!, yes, thats exactly it.
5 Lug Corolla WHAT?
