Originally Posted by TMetalMan
Well I was already using a long 3/4" socket (which I ended up cracking...)
After seeing Adam's Drum-to-Disk tutorial I decided to pull the rear hub, which provided the necessary clearance to get to that bottom bolt. I also pulled out the speed sensor to prevent damage to it.
I just did last last week. Yes. It's very tight. I even brake my 3/8. Get PB Blaster and put it on, wait 10 mins, put PB again, wait 10 mins. Try to tight it then loss it, tight it loss it. If you can't loss it, put more PB and wait another 10 mins.
I put PB on one side when I doing things on the other side. Then it's easy to take it off. It spend me 2x10 mins to take off the first bot, but after that, just 10 mins each.
Mine is original from toyota and 330k km already, so the nuts are pretty rusty..... Good luck...
Make sure you put socket on the other side. it will turn when you loss the bot on your side...
