I rebuilt a '99 5SFE last year with 172K on the clock. I removed the balance shafts because the main and rod bearings were worn. I split the case, removed the shafts, tapped the oil passage in the block, cut off a bolt and cut a slot in it so I could turn it into the oil feed below flush with a screwdriver. Set the bolt in with thread sealer to plug the oil feed passage, then re-assembled and attached the empty case. That way, I did not need to build a strainer mount. I could not tell any difference in the idle or run up with the shafts out. I drove that car about 500 miles.
I rebuilt an '01 5SFE this year with 102K, main and rod bearings were perfect. I reinstalled the balance shaft case with the shafts because it was easier to do so. Again, I could not tell that the shafts were in from the idle or acceleration. Drove it about 350 miles.
Maybe if the cars were side by side and you could drive one then immediately drive the other, you could tell a difference, but with several months in between, I could tell no difference.
Can't comment on the long term effects as I sold both cars. But if it were my personal driver, I might rather they were out. One less place to lose oil pressure.
