Terrible Gas Mileage 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2009, 03:30 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I got 19.7 mpg on my recent tank. No one drove the car but me, and I am VERY light on the gas. I do 0-60 in probably 15 seconds. Yeah, I'm a slowpoke.
I'd say I did about 100 miles on the highway and 170 in the city. I just had a Timing belt job done 500 miles ago. Is it possible that the belt is so new it's just getting "worked in"?
I just put new tires on and the car is aligned.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-12-2009, 05:29 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
try seafoam. i had very bad mpg.. 94 1mz and i would only get 200 miles a tank at most
after the seafoam i get at least 50 mile extra but depends on how i drive.. i got as high as 300 mile to a tank after the seafoam
also try a tune up after the seafoam
Old 09-12-2009, 08:42 PM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $440405
View rusty9's Photo Gallery
i had weird milage on my old 5s, if i was on a trip i could easily get 500+ miles on the highway keeping it at about 2500 rpm. but in the city i would only get around 200-250
rusty9 is offline   Reply With Quote
Old 09-12-2009, 09:53 PM   #4 (permalink)
Slowly learning....
My spark plugs are old, I know that. Wires look solid. I cleaned out the throttle body recently and my air filter is clean.
Maybe I'll try the spark plugs.
Old 09-13-2009, 01:32 PM   #5 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
What grade of oil are you using? If it's too thick, your engine will work harder. Do you carry alot of stuff in the trunk? Extra weight affects your MPGs. Recheck your tire pressure. Change the plugs, wires, cap, rotor, and PCV valve. Do the seafoam thing. It does help.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 09-13-2009, 03:37 PM   #6 (permalink)
Slowly learning....
I use 89 I think. The cheapest option available in Chicago. Trunk is almost always empty. Sometimes jackstands or some books.
My tire pressure is at 30psi. I put on new tires and that's what they filled it to. It looks a little low, my dad said I should do 35 psi. Opinions?
I don't know what the "cap", "rotor" or "PCV valve" is, or if it's expensive. I'll definitely do the seafoam eventually.
Old 09-13-2009, 04:19 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
retrospect try NGK plugs along with their wireset. plugs are mentioned (together with DENSO) in Camry manual, model# is NGK BKR6EKPB11, at least for 2000 camrys and solaras i4, might to double check that. you can get both in Advance Auto pasts store.
plugs and wires can make hell of a difference in comfort of driving and MPG. try it. it's a part of 30k tune up (together with fuel filter) anyways.
Old 09-13-2009, 04:32 PM   #8 (permalink)
Slowly learning....
Ah yes, fuel filter. I keep hearing about that, and with how much this car was neglected by the previous owner, I'm sure mine is ancient. Is that hard to install yourself?
Old 09-13-2009, 04:45 PM   #9 (permalink)
抵抗は無駄です
fenixus's Avatar
it's not that hard, however one of bolts maybe a problem to remove. some DIY here:
http://www.solaraguy.com/viewtopic.php?t=25792
or here:
http://www.toyotaownersonline.com/pu...HowToBroch.pdf
I let the mechanic do this. i didn't feel comfy about messing with fuel lines anyways... no mechanic here.
have you tried replacing the PCV valve? may help a bit too:
it's located on top of engine head and connects to the throttle body. very cheap ($5) in autozone, takes 5 mins to replace, you only need pliers to do this.
"cap" is a distributor cap, the thing that's on the other end of spark plug wires. official DIY here:
I found lots of interesting DIYs in here:
Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
and here:
http://www.solaraguy.com/viewforum.php?f=20
plus some basic stuff here:
http://www.toyotaownersonline.com/pa...rvice/diy.html
Old 09-13-2009, 10:40 PM   #10 (permalink)
uibalnme's Avatar
Originally Posted by Retrospekt View Post
I use 89 I think.
What I meant was the weight of oil use(10w-30, 10w-40...) not the octane rating of the fuel you're using.
Old 09-14-2009, 12:11 AM   #11 (permalink)
Slowly learning....
Ooooh.
Honestly, I'm not sure. The car had a brand new oil change done when I bought it, and I haven't driven anywhere near 3,000 miles yet.
A shop would probably use 10W-30 right? It was serviced at Jiffy Lube according to the windshield sticker.
Old 09-14-2009, 01:08 AM   #12 (permalink)
Micky Blue Eyes
View Mickyblue's Photo Gallery
ALSO! if you have ever done a tune up yourself and you didnt use TOYOTA APROVED spark plugs and wires and cap and rotor, that could be your problem, Because i have done that, and i used to get 33-35mpg all day long on the highway and 26 in town, now because i did a cheap tune up a while back with bosch spark plug wires and autolight plats, i now get 29mpg and 20 in town.
Mickyblue is offline   Reply With Quote
Old 09-14-2009, 02:47 AM   #13 (permalink)
uibalnme's Avatar
Well, bosch is garbage when it come to our cars. Use NGK or Denso parts and you'll be golden.
Old 09-14-2009, 11:43 AM   #14 (permalink)
View TonsOfToyotas's Photo Gallery
maybe the o2 sensor? i know my celica (5sfe) ran shit until i replaced that but id def check the cap and rotor to make sure it aint all burned up, besides the fact that its not good mpg does the car run okay? sputters? backfire? miss at all?
TonsOfToyotas is offline   Reply With Quote
Old 09-14-2009, 12:59 PM   #15 (permalink)
Slowly learning....
The car drives fantastic. Ride is smooth, always starts up right away. I may sound crazy here, but I'd compare the ride quality comparable to my Dad's 2010 Camry. It's perfect.
Only thing I can think of would be slow acceleration, but that probably has to do with the car being slow itself, haha. It does go when I punch it though, so probably not an issue.
