Where Get 12V in Engine Bay When Engine Runnin - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2009, 07:07 AM   #1 (permalink)
Camry: 94-I4 and 94-V6
View sintox's Photo Gallery
Question Where Get 12V in Engine Bay When Engine Runnin
HI ALL,
In the engine bay, I'd like to have a power supply of 12V when the car is running, and 0V when the engine stops.
Without opening the thing where all the wires pass (top firewall, passenger side, engine-bay): Where can I get that power ?
Where is the most easy place to hook up ? (My engine-bay is very messy with black oil due to rust-proofing many times in the long past ).
THANK YOU SO MUCH.
sintox is offline   Reply With Quote
Old 09-14-2009, 12:52 PM   #2 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
What are you trying to power?
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 09-14-2009, 01:53 PM   #3 (permalink)
View FireFire's Photo Gallery
and how many amps you need to?
FireFire is offline   Reply With Quote
Old 09-15-2009, 08:02 AM   #4 (permalink)
Very little power for the Oxygen sensor heater-connected to a thermo-switch. The heater must be very small so the power needed is very small.
Old 09-15-2009, 12:02 PM   #5 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
ho many volts is need by the heater thing you are trying to connect?
Old 09-15-2009, 12:32 PM   #6 (permalink)
12V
Heater will run until the block is slightly warmed up (5-10 minutes for the thermal-switch to open)
Old 09-24-2009, 08:33 PM   #7 (permalink)
View Dick Tuck's Photo Gallery
Get the wiring diagram for the car-- may be on the 'net. There is usually a a main 12 v relay which powers the fuel injection and goes on with the key.
Dick Tuck is offline   Reply With Quote
Old 09-25-2009, 06:01 AM   #8 (permalink)
Thanks Tuck.
I ended up using a new Relay, placed next to the battery, then run a wire through the rectangular rubber grommet (passenger side, near right strut tower). To pass the wire, un-do the black taping then use a coat-hanger to pull the wire through.
