Rundown of what goes into a full tune up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2009, 09:17 PM   #1 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
I'm going to do be doing a tune up sometime before this winter. I'm just trying to compile a list. Take to mind this car was extremely neglected. It had the original timing belt on at 148k, so it probably needs everything.
The obvious:
Spark plugs
Wire set
PCV Valve
Distributor
Air Filter
Fuel Filter
The specific:
What am I missing?
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-18-2009, 09:57 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i would seafoam
oil change /oil filter
maybe coolant change
top off all fluids
charge battery
Old 09-18-2009, 10:42 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
flush all fluids too...ALL. PS, tranny, brake, oil, and coolant.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-18-2009, 10:48 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
power steering fluid too? never heard of that one to be a part of tune up... how often do you guys flush it? on your own or in a shop (like tranny) ?
Old 09-18-2009, 10:51 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
is seafoam really going to improve anything on lower mileage (66k) cars too? i did some TB cleaning (used a can of TB & carb cleaner) last time, there was only lots of smoke right after and then everything was like before LOL
Old 09-18-2009, 10:57 PM   #6 (permalink)
Slowly learning....
I'm a bit scared doing this myself. The tranny, oil, and coolant I think I could do on my own. But I heard to do the power steering you have to watch it flow out, and add at the same time because you can't let air in. Sounds tricky.
Old 09-18-2009, 10:59 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
PS is one of the more common problems on the camrys. flushing will help pevent problems later that WILL happen, but meeh...its not the most important and may not be necissary.
seafoam can be done whenever and is almost always a benifit.
but you said you wanted all that was involved...this is what we are recomending. take whatever advice you want..but a tune up is a tune up...as we see it. things like pcv valve and wires are things to replace when they go bad. nice to have juat in case...but "dont fix till its broke" kinda things.
R.I.P.
Car Domain:
Old 09-18-2009, 11:02 PM   #8 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
i don't want to take my motor apart to change my back 3 spark plugs :-( ha ha... so many steps in my hayness. oh well... tomorrow we'll see ha ha
loves it when i make ppl regret not downshifting ;-)
TRUST YOUR DRIVER RESPECT YOUR MONKEY
http://www.cardomain.com/id/slpr1mz
slpr1mz is offline   Reply With Quote
Old 09-18-2009, 11:02 PM   #9 (permalink)
Slowly learning....
PS is one of the more common problems on the camrys. flushing will help..but at 66K...meeeh, its not the most important.
I do want all that is involved, and I appreciate the advice. I didn't know I should flush any fluids.
I guess I was just asking which of those I could do on my own (Inexperienced guy. I just fix what I can by doing research, no real automotive background.)
Old 09-18-2009, 11:13 PM   #10 (permalink)
I HAS BOOST!!!
bigbird's Avatar
understandable...flushing is tough by ones self. but detailed is detailed. the more important are the oil, tranny and coolant. even if ya cant do a full flush...a change will be a great benifit along with the other things youve listed.
seafoam especially
R.I.P.
Car Domain:
Old 09-18-2009, 11:21 PM   #11 (permalink)
Slowly learning....
seafoam especially
I'll ask my uncle for help with the fluid flushes. The coolant in there right now is pretty new. Timing belt was done 500 miles ago.
Thanks again.
Old 09-19-2009, 12:01 AM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
at least spark plugs and wireset are both very easy on 5s-fe ... both take less than an hour. coolant flush is very easy even if you don't have jackstands to drain the engine block too. when you choose flushing with radiator drain only you can take a look here:
Coolant flush: Do you remove engine block drain plug?
brake system flush is not very complicated either:
DIY: 1996 Camry Brake Fluid Flush Procedure (GEN3)
