Camry 93 V6: Error code 55 missing from error code lists? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2009, 12:39 AM   #1 (permalink)
View jopki's Photo Gallery
Canada Camry 93 V6: Error code 55 missing from error code lists?
I started getting error code 55 and all lists of codes I know of have it missing - doesn't exist... Any ideas? I get it every time I drive now. Thanks for any lead on this.
JE
jopki is offline   Reply With Quote
Old 09-20-2009, 11:00 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
can you recheck the code? i cant find anything on this either ....
^ and leaving it that way!
Old 09-20-2009, 12:18 PM   #3 (permalink)
I will re-check. The only explanation I would have is that there were 2 codes "5" and another "5". I will align the blinking decoder in my brain with another fault artificially introduced, such as mass airflow sensor disconnected. Thanks, chronoti, for your interest. Somewhat, it might be plausible since my mechanic might have messed around the O2 sensor area (which would be code "5") when he replaced my thermostat... or, it is just a coincidence and my O2 is now detected as bad when cooling system works correctly... who knows?
One more question: Is there an easy way to determine O2 cycling just by watching the Ox1, Ox2 pins with an analog voltmeter? I couldn't find any recipes to do that. I will try my old corolla book to see if they have a blurb on that - it should be the same, I think...?
Old 09-20-2009, 12:29 PM   #4 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
i think the voltage readings should be 0.1 - 0.9v while idling
Old 09-20-2009, 02:33 PM   #5 (permalink)
Canada
Attaching the mysterious code 55 (image of an audio recording while I whistled during the lamp blinking) You can see that the gap between the first 5 and the second 5 is about 1.8s which is the same as the separator between the 2 and 4 (code24) and 3and 1 (code31) . It is also possible that there is a BUG in the Diagnostic firmware which makes it appear as code 55 but in fact are two separate code 5s.
Old 09-20-2009, 02:34 PM   #6 (permalink)
I will erase all and try to "get only one "5" if I can.
Old 09-20-2009, 02:37 PM   #7 (permalink)
Canada
Thanks, abew330. How do you measure it? Against ground?
JE
Old 09-20-2009, 03:03 PM   #8 (permalink)
View LUVLEXUS101's Photo Gallery
I think its ecu not making contact with knock sensor #2
LUVLEXUS101 is offline   Reply With Quote
Old 09-20-2009, 04:33 PM   #9 (permalink)
It does look like Code 55 !
Ok. I erased the codes,
1) Started with cold engine, drove 2km = No Codes.
2) Started engine again, got it to temp by idling 10 mins = No Codes
3) Drivig the car 100 m = Engine Light turns ON.
Stopped within 5 sec. Read the error codes: 5 blinks over 4.5 sec, 1.5 sec pause, 5 blinks over 4.5sec, 4.5sec pause and repeat the above. (+/- 0.3sec or so)
4) Started the engine again = Engine Light stays OFF but it will come ON again I have seen it do that before.
Old 09-20-2009, 04:37 PM   #10 (permalink)
Canada
Thanks, luvlexus101, Do you have a list that would apply to my 93 camry v6 with 3VZFE, that includes error code 55? Do you know where knock sensor #2 is exactly located?
Thanks,
JE
Old 09-20-2009, 05:04 PM   #11 (permalink)
96 3MZ M/T
chronoti's Avatar
i would work on the other 2 codes 1st and see if that 55 was just off of those.
http://toyotaownersclub.com/forums/i...t=#entry773939
Old 09-20-2009, 07:12 PM   #12 (permalink)
Canada
Sorry I didn't make myself clear: I deliberately caused the 24 and 31 (MAF disconnected) to have a reference to see how big blinking gaps are between the 2 and 4, 3 and 1 and if it is the same as between the 5 and 5. The code 55 is the only error I am getting now.
Old 09-20-2009, 07:54 PM   #13 (permalink)
Canada
Thanks. luvlexus101 for the lead. I found this thread Fooling the ECM - sharing 1 good knock sensor for 2 ECM inputs which appears to be my case. I am still puzzled though why code 55 cannot be found in the standard toyota error code lists ... ?
Old 09-20-2009, 08:47 PM   #14 (permalink)
Gameroom cash: $303255
This site shows codes 52, 53, and 55 as Knock sensor codes:
http://www.extreme-check-engine-ligh...%20Decoder.htm
Mike
Mike Gerber is online now   Reply With Quote
Old 09-20-2009, 11:10 PM   #15 (permalink)
thx!
