Tap Water instead of Coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2009, 03:06 PM   #1 (permalink)
View jopki's Photo Gallery
Canada Tap Water instead of Coolant
Are there any adverse effects of filling tap water instead of coolant?
(Little mileage, Just for a few days until my leak is fully sorted out.)
JE
jopki is offline   Reply With Quote
Old 09-20-2009, 03:44 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Water will give better cooling, but will freeze at 32 degrees F.
Tap water has impurities that can over time clog up a cooling system. This is why it is always suggested to mix DISTILLED water with concentrated anti-freeze.
If it is only for a very short time, you will probably be fine, just make sure to flush all of it out afterwords.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 09-20-2009, 07:21 PM   #3 (permalink)
View djb2's Photo Gallery
How much antifreeze is left in the system? If it's at least 10% you should be OK for a few weeks.
The antifreeze acts as a seal lubricant and has anti-corrosion additives. You don't want to 100% water because it will wear the water pump shaft seal faster, and you don't want to run a low percentage for very long because the anti-corrosion additives deposited on the metal surfaces will wear away.
djb2 is offline   Reply With Quote
Old 09-20-2009, 07:30 PM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Yeah it shouldent be a problem for a few days/ a week.
carsrus is offline   Reply With Quote
Old 09-20-2009, 08:05 PM   #5 (permalink)
Canada
Thanks, guys, it is still a bit green so I would guess 10% or so. but my leak is handled now so I will replace it with proper coolant probably tomorrow.
Old 09-21-2009, 12:17 AM   #6 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
+1
93XLEcamry is offline   Reply With Quote
