help 97 camry won't start - timing belt problem
I have a 1997 camry 4 cyl, with 209XXX miles, this is what happened, one night I was driving the car and I heard a sound coming from the engine, I stopped the car and i noticed that the sound was coming from the timing belt . I had no choice but to drive it that way home (5 minutes away) for some reason I took the cover out ( top cover)belt seemed lose, I thought the belt tensioner were in the botton cover so i took it out but i was wrong and i didnt make any reference in the belt so i tight the belt but I didnt line up the cam and crank so i start the car but it didnt start, so i noticed i had to line it up, finally I did it but car wont start. I dont know what I did wrong I clean the spark plug they're good, check fuel is good, my car doesnt have distributor it has coil pack they're good, what else could be? I talked to a mechanic he said I may have bent the valve, I need Help!
