no brake lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2009, 10:47 AM   #1 (permalink)
View mlmattson2's Photo Gallery
Question no brake lights
I have a 1992 Toyota Camry. The brake lights have all gone out. None of them are working. The shift lockout is also making it so that I can not shift out of park unless I press the button and hold it well I shift out of park. We have checked all the fuses and relays that we can think of, and the wiring under the dash. Any one else had this problem? or have any idea of what to look at? I need to take my son to the doctors but can't go anywhere with no tail lights.
mlmattson2 is offline   Reply With Quote
Old 09-21-2009, 11:11 AM   #2 (permalink)
Proud Camry owner.
Loganwiththe'93's Avatar
View Loganwiththe'93's Photo Gallery
Can you pull a code? That would help I'm sure.
1993 Toyota Camry LE 4 Cylinder
Running 100%
Loganwiththe'93 is offline   Reply With Quote
Old 09-21-2009, 11:15 AM   #3 (permalink)
I'm new to owning a Toyota so I have no clue how to pull a code on it and none of the shops around me can tell me how and I can't afford the amount that they charge just to have them see if there is a code coming up on it.
Old 09-21-2009, 11:26 AM   #4 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
There's a switch attached to your brake pedal. That switch actuates the brakes lights and the shift lock release. That switch or associated wiring is bad.
No idea where you go from here as I've not fixed one before.
2007 Camry 2.4L 5M
Old 09-22-2009, 04:29 PM   #5 (permalink)
Smile
Thanks for the help.
