Lower the window.
Remove the door trim panel
remove 2 bolts holding main window
Pull the main window up and out of the door.
Remove door glass run
Remove the 2 glass channel mounting bolts and a screw
Pry the glass channel from the bottom of the window.
cant remember but i think you can just remove the window glass WITH weatherstrip together by pulling forward..
otherwise
Peel off the weatherstrip on the upper side of the vent window. Remove the 2 - 3 screws
Pull the vent window up and out of the door frame.
To install
Coat the inside of the weatherstrip with soapy water and TAP the glass channel onto the bottom of the window.
Slide the main window into the door until the 2 glass channel mounting bolts can be fitted.
Position the vent window and install the 3 mounting screws and the set bolt. Tighten the 2 glass channel mounting bolts.
Install the weather-strips.
