Help with fuel leak please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 05:24 AM   #1 (permalink)
View xcmtb83's Photo Gallery
Hello,
I have a 1995 Camry with 96,000mi and a nasty fuel leak in front of the rear driver's side wheelwell dripping off of the lines. I am not 100% positive about where it is leaking from but I am confident that it is not the filler neck because it is the opposite side. Is the location I describe a common spot for a fuel leak? If so what is the problem do you think and how could it be fixed. My plan is to fix any and all possible leaks by replacing the tank and lines and also the filler neck just because the neck is going to leak eventually. Where can I get the fuel lines, filler neck and a gas tank at a fair price? Thanks for any and all input!
xcmtb83 is offline   Reply With Quote
Old 09-22-2009, 07:31 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
do a search ... but
DIY: Fuel Filler Tube Replacement Procedure (GEN3)
that was a few pages back.
^ and leaving it that way!
Old 09-22-2009, 06:42 PM   #3 (permalink)
not your average bear
View justchillinjefe's Photo Gallery
I just replaced all three fuel lines on my 95 1mz camry.
I bought the lines pre bent from the dealer for $107.00 for all three (fuel send, fuel return, vapor line).
They are not hard to put in place. You will likely need new plastic clips to hold all of the lines to the body. They were $11 a piece from the dealer...
Might wanna get a new fuel filter, as it is easier than trying to undo the old one.
Hope this helps.
justchillinjefe is offline   Reply With Quote
