Wiper fluid not spraying - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 10:09 PM   #1 (permalink)
slcpunk's Avatar
View slcpunk's Photo Gallery
97 Camry. When I pull the lever for wiper fluid to spray on windshield only the left side works. Any suggestions? Is this a common problem? Thanks in advance.
1997 Toyota 204k miles. Runs like a champ.
slcpunk is offline   Reply With Quote
Old 09-22-2009, 10:18 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
try to clean the jets with a tooth pick
Old 09-22-2009, 10:19 PM   #3 (permalink)
slcpunk's Avatar
That was fast, thanks. Good idea, I'll give it a go tomorrow when I have some light.
Old 09-22-2009, 11:35 PM   #4 (permalink)
slcpunk's Avatar
Well I ran out there with a shop light and gently poked it in there and nothing different. Really looking at it, there is nothing on the right side and the left side seems extremely weak. Think maybe it just needs a new pump/motor?
Old 09-24-2009, 08:18 AM   #5 (permalink)
View Camry LE 94's Photo Gallery
look under the hood where the little rubber tubes go into the jet... the one that doesn't spray might of come off?
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 09-26-2009, 12:14 AM   #6 (permalink)
View chick.with.a.wrench's Photo Gallery
Some wires might be loose between the pump and the sprayer. I would check those lines and if there seems to be no noticeable damage, have someone else engage the fluid while you check for leaks anywhere in the lines. If there are none than yeah... you probably need a new pump or just new lines.
I'm no damsel in distress on the side of the road. If you see me on the side of the road with a hood popped open, It's because I'm there to rescue the REAL damsel in distress and sweep her off her feet.
chick.with.a.wrench is offline   Reply With Quote
Old 09-27-2009, 01:43 AM   #7 (permalink)
slcpunk's Avatar
I appreciate the feedback, will check it out tomorrow.
