Overheating / Slow (broken) fan? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 10:21 PM   #1 (permalink)
Proud Camry Owner!
MordyT's Avatar
View MordyT's Photo Gallery
3rd Generation Overheating / Slow (broken) fan?
I have another 94 Toyota Camry V6 Japanese Model at my shop right now for repair. It has had the following repairs:
2 Water Pumps
2 Thermostats with Gaskets
And it still overheats. I noticed that the fan is slow – so slow that I can stop it with my hand and hold it. I can even count the fan blades.
I understand that there is an ECU, control valves, pump, motor, cooler, and the filter.
I am unsure how to figure out what is causing the low fan speed.
I am not sure if it is relevant, but the power steering works fine. Reason I mention this is because the fan is powered by hydraulic fluid from the pump. However, I do believe that there are 2 separate parts to this pump? One part for the steering and one for the fan so this may not be a good indicator.
I obviously don’t want to start ripping apart the system trying to figure it out by replacing everything one at a time, so I am asking if anyone knows a quick way to figure out which part is at fault – Pump, valve, controller, etc.
My Ride: 1994 Toyota Camry V6 XLE 3.0L
MordyT is offline   Reply With Quote
Old 09-22-2009, 10:30 PM   #2 (permalink)
The womaneater!!!!!!!!!!!
samarai912's Avatar
View samarai912's Photo Gallery
what kind of motor is it? strange that its not an electric fan. havent heard of this before. let me know. what kind of system are you using? alldata? mitchell?
GF:"samarai I want to marry you." Me:"Uhhhh..I made a mistake.I only love my car"
Camry gen4 1mz turbocharged @ ? bar(updated)
.http://www.cardomain.com/ride/3029563
samarai912 is offline   Reply With Quote
Old 09-22-2009, 10:59 PM   #3 (permalink)
View lee777's Photo Gallery
Does it overheat at highway speeds, when there is lots of air movement?
If so, could be radiator. Is the rad original?
lee777 is offline   Reply With Quote
Old 09-23-2009, 01:01 AM   #4 (permalink)
Proud Camry Owner!
MordyT's Avatar
I use mitchell 5.8. As for the fan I will agree that it is strange that it is hydrolic powered but on my own personal car and it has the same config except the fan works. I don't know what you mean by motor - there is a line with power steering fluid to the fan.
I guess it is time for a roadtrip on the highway.
Old 09-23-2009, 05:10 PM   #5 (permalink)
Proud Camry Owner!
MordyT's Avatar
It looks like the radiator was replaced. I didn't have time to roadtest it on the highway but from the sticker on it, its apparent that the rad was replaced within the past year.
Any ideas.
Old 09-23-2009, 05:41 PM   #6 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
its not really rare, the hydraulic fan was the standard fan for the 92-93 V6 models, wierd it ended up on a '94 though. It's more of a pain to service but, when its running it does its job well. That being said, it should be moving quite faster.
When does your overheating occur, if it only occurs at idle & stop & go, its prolly your fan, but if you have this issue at highway speeds its something else, I not sure what if you replaced your water pump recently.
NVM i should of read more closely.
if the thermostats were replaced & the pumps, Im kinda lost.
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 09-23-2009, 08:34 PM   #7 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
wow, well. the fan impeller, is worn, take the fan hydrological motor apart and you see the blades of the impeller have worn down or the impeller bearings allowing the fluid to pass by and not really turn the impeller. the fan is prolly just turning right now because of the flow of the current around the impeller.
that or the hose is clogged.
^ and leaving it that way!
Old 09-23-2009, 08:43 PM   #8 (permalink)
Bdub215's Avatar
Gameroom cash: $315565
View Bdub215's Photo Gallery
Power steering pump. drives the fan so if its not putting out like it should be i'd look there. @ the_professional the hydraulic was on ALL camry v6/es300 between 92-96.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 09-23-2009, 08:57 PM   #9 (permalink)
96 3MZ M/T
chronoti's Avatar
nope wrong i have a 96 electric fans. it was mainly only the 3vz but there were a few stragglers that made it in to the 94 years. you know left over parts like how a few 96 have the serviceable struts.
Old 09-23-2009, 09:18 PM   #10 (permalink)
Bdub215's Avatar
my 95 es300 had it so it couldnt have stopped at 94
Old 09-24-2009, 02:03 PM   #11 (permalink)
View davemac2's Photo Gallery
From what I've heard, these hydraulic fans rarely fail. You want to make sure that there is suffcient fluid in the PS reservoir, because when the fan circuit kicks on, it will suck a lot of fluid from that. You can try to manually activate the fan high/low solenoid at the PS pump by removing its connector and applying power directly and see what the fan does. (I think shorting
OP1 and E1 on the data link connector under the hood near the passenger fender will do the same thing.)
You can also check hydraulic pressure on the fan circuit I would imagine by removing the high pressure line at the top of the hydraulic fan motor and inserting a pressure gauge inline with it there. You will need some type of banjo fitting adapter to go onto the high pressure hose. (Pressure should be 140-280 PSI @2000RPM I think with high speed enabled?) From the Toyota manual, it does appear that the PS and fan hydraulic flows are totally separate, so it may be possible for the fan side to suffer a pressure loss from the pump and not the PS side?
Another alternative: ditch the hydraulic fan and replcae it with an electric one somehow.
dave mc
davemac2 is offline   Reply With Quote
Old 09-24-2009, 02:57 PM   #12 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
my camry 94 v6 LE has hydraulic radiator fan as well, as soon as the engine starts, the fan runs, but at a very low speed, just one big fan, i noticed my 93 camry, 2.2L radiator has two eletric fans though, and the electric fan won't run until the radiator is above normal temperature range.
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 09-24-2009, 04:37 PM   #13 (permalink)
TOYODA KAMURI
I don't know, I've worked on '95 & '96 V6's with electric fans, I can't be 100% sure about '94s.
