Car hits bump....steering wheel goes NUTS !! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2009, 11:36 PM   #1 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
What the hell is up? This is probably the BIGGEST problem I have with my 92 I4 Camry. So im driving along and I run over a bump...could be a simple or huge bump...I go over it then suddenly my steering wheel turns left or right. I have to fight with the steering wheel to keep it straight..... When im driving over a smooth surface everything is fine and the steering wheel stays stright....if i suddenly run over a bump or hole if im not holding the wheel the car would end up in a ditch. What could the problem be? Bad shocks? Steering rack? Power steering fluid?
When I drive my sis 2005 corolla and my 99 GS400, I can roll over a bump and the steering wheel wont budge... Is this just how these years Camrys are? Am I holding my 17 year old Camry to the standards and expectations of newer better built cars?
My steering is just not "Tight". It pisses me off. When the car is off, no key in the ignition there is so much damn play in the wheel. I could literally almost turn the wheel half way when the car is off. In my GS the steering is so tight there is almost no play in the wheel. To give more detail into what im trying to get at, I have my head out the window looking at the front wheel.....I then turn the steering wheel a little the front wheel doesn't move. Turn it a little more they still don't move...turn it some more and FINALLY the front wheel begin to turn. This is what i mean when I say its not tight and there's to much play in the steering . It does not give me the confidence I need when I drive my Camry hard and fast....but its been like this for so damn long im used to it. Does any one else experience this or have these issues with their Camrys? Could be any year really
TravisAe86 is offline   Reply With Quote
Old 09-22-2009, 11:56 PM   #2 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
the same thing with the steering and the bump is happening to me too...i've been wondering what was wrong too...sorry if i tread jack..
93XLEcamry is offline   Reply With Quote
Old 09-23-2009, 12:16 AM   #3 (permalink)
Toyota 4 Life
TravisAe86's Avatar
Its cool bro...this is my biggest problem by far on my Camry. You notice it even more when you drive a different car. The front wheels and the steering wheel are not seeing eye to eye...
Old 09-23-2009, 12:29 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $349253
View BMR's Photo Gallery
Something's wrong. The steering wheel should not have that much play in it. I suspect the problem's either in the rack & pinion, or possibly in the joint connecting the steering wheel shaft to it.
BMR is online now   Reply With Quote
Old 09-23-2009, 12:35 AM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Yep, owned 3 Gen 3's. One killed by a semi at 160K, another at 80K, (F'ing semis!) and one parked at 250K. Never had any such problem so sounds like you need to get this sorted out.
Dave's is offline   Reply With Quote
Old 09-23-2009, 12:44 AM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Among the things, ball joints should be inspected. See what happens when they break:
http://www.tegger.com/hondafaq/lowerballjoint/index.htm
And on the Toyota Lexus line:
http://www.clublexus.com/forums/susp...with-pics.html
l
Old 09-23-2009, 12:55 AM   #7 (permalink)
93XLEcamry's Avatar
OOOOMMMMMMMMMMMFFFFFFFFFFFGGGGGGGGG......now im scared....cus every time i turn my wheels to the right i hear clicking noise....
so i need to get the ball join fixed to get rid of the steering play and the clicking noise right?? again sorry sorry to tread jack bro...
Old 09-23-2009, 01:13 AM   #8 (permalink)
Toyota 4 Life
TravisAe86's Avatar
Thanks for all the info guys...you guys are really helpful believe it or not =D
Old 09-23-2009, 01:14 AM   #9 (permalink)
Clicking while turning could also be outer CV joint. However, a worn CV joint should not change your alignment geometry. But you may have multiple problems??
Soooo.....not counting struts, wheel bearing, strut bearing, stabilizer bar links, outer CV joints, or other suspension components, but I'd say ball joints are among the things you should inspect here (lower ball joints, outer tie rod joints, inner tie rod joints).
A mechanic should check all suspension/steering components and try to identify the real source of the noises. But ball joints are among the usual suspects here.
Old 09-23-2009, 01:16 AM   #10 (permalink)
Toyota 4 Life
TravisAe86's Avatar
speaking of rack and pinion....theres this part that's busted by my wheel....im goin to take a pic of it and post it...would love if u could tell me what it was bro
Old 09-23-2009, 01:29 AM   #11 (permalink)
93XLEcamry's Avatar
how would i go about checking for a bad ball join???....
Old 09-23-2009, 10:50 AM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
had that thought it was my lower control arm bushing, got it replaced and too it to toyota for alignment to get done, found the rack was loose.
^ and leaving it that way!
Old 09-23-2009, 11:33 AM   #13 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
trevisae86 - the first thing i would do is rotate the front tires to the back then test drive the car to rule out any wheel unbalance problems. since these cars are rack and pinion, i would then focus on that. i dont think bad struts or ball joints would cause the steering wheel to turn back and forth rapidly.
to check for bad ball joints, remove the front wheels. inspect the rubber boots for the ball joints. if they are intact and not leaking, grab a long prybar and see if you can pry the steering knuckle away from the lower control arm. be careful not to pinch the rubber boot. there shouldnt be any movement when you try to pry.
Old 12-17-2009, 04:41 PM   #14 (permalink)
A camry n00b
peshwa's Avatar
Gameroom cash: $257859
View peshwa's Photo Gallery
TravisAE86 and 93XLECamry
What did you guys end up doing? What were the root causes? Care to share? :-) I need your help!!
1995 Camry DX L4 178,6XX miles and counting each mile.... acquired 05/25/2007 at 129K miles
2004 Mazda6 I4 5-Speed Manual 115,500 miles acquired 01/21/2011 at 109,XXX miles
peshwa is offline   Reply With Quote
Old 12-23-2009, 04:31 PM   #15 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
my money is on loose steering rack. worn/missing bushings, or simply not bolted down on one side. that could defintely do what he's describing, and would be scary as hell!
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
