Where to Tap in dome light 12V - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2009, 08:10 AM   #1 (permalink)
TOYODA KAMURI
the_professional's Avatar
View the_professional's Photo Gallery
Im contemplating putting white footwell lights in the camry, and I want it to function much like the 3 way switch on the dome. Is this possible & where can I tap in for both left & right footwell lights? Thanks!
i love my 1992 Toyota Camry LE 2.2L 5S-FE - 73K
9005 NIGHT GUIDE LOW BEAMS|FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS KA7 3.2L C32A - 87K
SADLY, SHE HAS MUCH MORE MODS...
the_professional is offline   Reply With Quote
Old 09-23-2009, 08:51 AM   #2 (permalink)
The guy with a maroon 92
n3rdifed's Avatar
View n3rdifed's Photo Gallery
hmmmm i was going to ask this question too! where could we tap?
n3rdifed is offline   Reply With Quote
Old 09-23-2009, 10:54 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
the contact points on the bulb. the switch doesn't feed back to a body control modual.
^ and leaving it that way!
Old 09-23-2009, 05:27 PM   #4 (permalink)
TOYODA KAMURI
damn.
i guess it would it be more convient then to run from an always live 12V, & just run a switch.
idk, I prolly would need to wire the lights from the negative on the dome than to have it work. =/
right? or both the (+) & (-) leads & have to wire it back down, I'm a little fuzzy on how the dome works.
the 12V for the dome runs through the A-Pillar?
Old 09-23-2009, 06:01 PM   #5 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Do you want the lights to turn on when you open the door? Thats doable.
Take off the dome light . Theres a 2 pin connector. Splice or shove your wiring into the connector. Its that simple. When you open the door the switches in the doors close the ground and the lights turn on. If you want constant 12v from that source simply splice into the positive on the dome and ground it to the ground screws on the dome light.
I did this to my gen 4 last weekend so if you got any questions fire away.
carsrus is offline   Reply With Quote
Old 09-24-2009, 12:57 AM   #6 (permalink)
n3rdifed's Avatar
post a diy!
Old 09-24-2009, 11:00 AM   #7 (permalink)
#2!
Gameroom cash: $102128
View #2!'s Photo Gallery
What if you ran a constant 12 to a relay and got the input from the illuminated key ring? Just a thought. I havent really payed much attention to it but lit up seems to be at the right times when you would want.
#2! is offline   Reply With Quote
Old 09-24-2009, 04:40 PM   #8 (permalink)
TOYODA KAMURI
Yeah, I thought of that too.
It seems it would be PITA to reach though, either that or I'm just scared.
Old 09-24-2009, 05:14 PM   #9 (permalink)
#2!
The electrical diagram shows its a green-red wire going directly to the bulb but can't say if iv ever seen it. A couple constant 12v wires are in that area behind the key cylinder also.
Old 09-24-2009, 05:38 PM   #10 (permalink)
TOYODA KAMURI
Thanks, do you think the fading function would cause any issue with the LED's?
But, I would also like to be able to turn these lights on at all times, Im kinda comfused.
Other than wiring speakers & a headunit I havent strayed into splicing car wiring.
Old 09-24-2009, 06:42 PM   #11 (permalink)
#2!
Your lights fade? If using a input wire to a relay the LEDs will just turn off and on. The LEDs I have used on dash gauges fade just fine with the dimmer switch though. You could also put a switch in the input with the key light just put a diode in the wire going up to the key light so the key light stays off when you turn the switch on.
