1992 camry electrical drain - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2009, 09:55 AM   #1 (permalink)
View socketcap's Photo Gallery
3rd Generation 1992 camry electrical drain
My 92 Camry battery goes dead with the engine off after about 8-12 hours.
I measured with a ammeter and there is a 5 amp draw on the battery with everything off and keys not in the ignition.
With my ammeter still connected I briefly pulled the fuses one at a time to try and find the mysterious draw and I still had a 5 amp drain.
This car has 264,000 on the odometer and it runs and drives great.
This car has a alarm in it and I think it is causing the draw, I tried to find some fuses under the dash that might have gone to it but could not find any.
I live in an extremely rural area and I have no need for an alarm.
I would like to disconnect the alarm and see if my electrical problem is fixed.
Is there any threads on this type of problem?
Has anyone had a weird electrical problem like this with their gen 3 camry?
Is there a way to find out if this car has a factory alarm or aftermarket alarm?
Is it ok to ask about disconnecting car alarms?
Sincerely,
Colin Morris
socketcap is offline   Reply With Quote
Old 09-23-2009, 10:57 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
the alarm fuse is prolly under the steering column with it fuse next to it you have to move the steel reinforce plate there to get at it.
dont forget to check the kick panel fuses. i had a radio that kept killing my battery, injunction with the bcm.
^ and leaving it that way!
Old 09-23-2009, 11:42 AM   #3 (permalink)
Gameroom cash: $303255
If it's an aftermarket alarm system it will probably have it's own inline fuse. Check for that.
Mike
Old 09-23-2009, 11:43 AM   #4 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
how old is the battery?
did you ever have on stereo/lights/etc.. on without the engine running?
if you think the alarm is killing the battery try disconnecting the alarm for one night and see if that was it.
obviously if the car starts in the morning you found the problem if not move to the next thing.
maybe you have a short somewhere causing your battery to drain
the alarm/box would most likely be under the dash (steering column)
Old 12-21-2009, 11:37 AM   #5 (permalink)
View Parkertm70's Photo Gallery
Yep i got the same prob i havnt messured the draw yet but if it sits for more than a day its dead. but if i drive it it will stay up so you think its not the alt bc it charges but i have had a couple of people say they thought there batt was bad on their camry and threw a battery at it but it was the alt that they finally replaced and it fixed it.
im not the type of person to not kno what i am fixing and throw parts at it but thats all i have came up with this problem
Parkertm70 is offline   Reply With Quote
Old 12-21-2009, 12:25 PM   #6 (permalink)
Many auto parts stores offer free testing of the alternator and battery while still on the car. Call around to auto parts stores in your area and ask if they offer this free service. If they do, drive it over and let them check it out for you.
Mike
Old 12-21-2009, 04:55 PM   #7 (permalink)
Ninja wrench anywhere
hill8570's Avatar
Gameroom cash: $177015
View hill8570's Photo Gallery
If you're not sure it's the battery or not, pop off the battery connectors and let 'er sit for for a day or two. If she's still dead when you hook 'er back up, you've got positive id.
Or take Mike's suggestion
Old 12-21-2009, 05:00 PM   #8 (permalink)
hill8570's Avatar
I don't know much about alarms, but did you disconnect the biggie fuses in the engine compartment to try to isolate (driver's side box, near fender)?
60W is a goodly amount of power -- I'd think you'd be able to isolate this just by the heat alone.
