What sensors need replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2009, 12:13 PM   #1 (permalink)
View duneman11's Photo Gallery
4th Generation What sensors need replacement
I have bought a engine from CA so it is a CA motor and was wondering what sensors i would need to switch to make it a fed motor as this is what my car is origionally the car is a 99 camry V6
any help would be greatly appreciated
thanks
duneman11 is offline   Reply With Quote
Old 09-23-2009, 12:37 PM   #2 (permalink)
'Yota Tech
View matted2thefloor's Photo Gallery
thanks
The main sensors that would most likley need swapping would be all the O2 sensors and the mass air meter. But if you got just a motor and are swapping just motors, then you don't have to swap those sensors because all of them will remain with the car when you disconnect the exhaust and the air intake tube.... you'll be bolting those back up, so no need to worry about swapping any of those. BUT... If you bought a parts car for the motor...then you would want to re-use all the sensors that came off your ORIGINAL motor/exhaust/intake tube, etc.
matted2thefloor is offline   Reply With Quote
Old 09-23-2009, 12:58 PM   #3 (permalink)
i do not have a parts car and the car was previously a I4
Old 09-23-2009, 01:35 PM   #4 (permalink)
'Yota Tech
I'm confused! Your car is a 4 cyl and the motor you bought is a 6??? If so.... That's going to be a bit more involved. Your going to have to swap ECUs, harnesses and possibly fuel system components. I'm sure there is someone on the boards that has done a swap before as I have not...
Old 09-23-2009, 02:30 PM   #5 (permalink)
i know what is involved and i have the componets its just that the motor came from california but i have a fed ECU for it
Old 09-23-2009, 02:40 PM   #6 (permalink)
'Yota Tech
You'll need Fed ECU, Fed AF/O2 sensors and cats and Fed mass air meter....but those aren't on the "motor". If you don't have those for Fed emissions, you WILL need them, those are different! You should have nothing to worry about otherwise...
The motor itself makes no difference what emissions system it is working with.
