Engine makes funny noise when I accelerate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2009, 10:31 PM   #1 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
Exclamation Engine makes funny noise when I accelerate
Well I just got my car back from the shop because it was making a funny noise when I start it up and drive it. Turns out there was a hole around my flex pipe. While the flex pipe got fixed but guess what? Its STILL making noise....but these noises are totally different.
When i press the gas a buzzing sound emits from the engine and the more I press the pedal the louder that sound gets. But wait there's more ! If i floor the pedal the buzzing sound gets louder but then this brrrrroooooom sound joins in....idk what to do. IDK if its the gasket, manifold....idk. My exhaust pipe has been welded 3 times because of it bursting and random cracks....idk where the noise and exhaust problem is steaming from...idk if is from my engine rocking/jump when I change gears that's making the pipes move/flex and then break.....
TravisAe86 is offline   Reply With Quote
Old 09-23-2009, 10:35 PM   #2 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Let the car sit until it has completely cooled. Start the engine, pop the hood. Stick your hands near the places where the different pieces of the exhaust bolt together. A common leak area is in between the manifold and the front pipe. It's a small circular gasket that deteriorates over time and leaks, and makes that weird noise that you are describing.
When I bought my car it was making this noise, but I didn't notice it. I thought the car is just loud because it's a 4 cylinder. I was wrong. Replaced the gasket and it's 5x quieter.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-23-2009, 10:53 PM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
i use seafoam to vapor check for leaks seafoam it and look to see where smoke is coming from you find your leak quick.
^ and leaving it that way!
