Turn signal buzzing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2009, 10:57 AM   #1 (permalink)
View rod jr's Photo Gallery
Turn signal buzzing
My '97 Camry LE turn signal is buzzing on occasion when activated, is the relay the cause and if so where do I find it ?
rod jr is offline   Reply With Quote
Old 09-25-2009, 12:27 PM   #2 (permalink)
View .Camryman97.'s Photo Gallery
usually that means both the front and rear turn signals are out on the left or right side
did it blink fast before??
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 09-26-2009, 07:09 AM   #3 (permalink)
I got parts aoktoyota.com
malayan's Avatar
View malayan's Photo Gallery
3rd Generation Turn Signal Buzz
If the bulbs are good then it is the turn signal switch.
On all the buzz that I troubled.. it was ALWAYS the switch.
If you replace it BE CAREFUL with the AIR BAG.
Wind the coil 3 times from the left before installing the steering wheel.
malayan is offline   Reply With Quote
Old 09-26-2009, 09:32 AM   #4 (permalink)
It does not blink fast and only makes the buzzing sound on ocassion.
Old 09-26-2009, 09:43 AM   #5 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I've noticed the same thing on the gen 3.5. It rarely happens so I haven't looked into fixing it.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 09-26-2009, 10:29 AM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i have it happen on occasion as well. more-so when i press it lightly just to flash the lights when im changing lanes on the highway. this has been going on since i bought the car in '05.
Old 09-26-2009, 11:36 AM   #7 (permalink)
View SirThomas88's Photo Gallery
Could it be the clicker thing going bad?
On my 2000 the device that makes the 'click' noise for your turn signal/hazards is located under the steering wheel to the left, hidden behind a plastic cover. It's a square black thing. When you have your turn signal/hazards on put your hand on it and you'll feel it clicking. That should be easy to replace, just pop it out and stick a new one in (make sure same model of course).
I wonder if that's it.
SirThomas88 is offline   Reply With Quote
Old 09-26-2009, 11:43 AM   #8 (permalink)
Yes I think thats the problem, but where is that cover located, I can't seem to find it.
Old 09-26-2009, 11:55 AM   #9 (permalink)
Here, I took a picture. It's under the steering wheel along the left by the door. I had to remove a single screw holding a plastic cover on and then pop it out. In the photo its the black box at the top of the image.
Old 09-29-2009, 07:47 PM   #10 (permalink)
Thanks so much Sir Thomas for the photo
Old 01-09-2012, 01:50 PM   #11 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Flasher Assembly Toyota part 81980‑12110
Tridon makes an equivelent EF35 superceded by FET13 I bought the EF35 last friday for about $15 CDN.
I was able to reach in the GEN4 camry to get it our without taking off the trim piece.
My 00 Camry had an OE (Factory made ) plastic adapter and metal clip to use a similar LBE type flasher in it's place.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
