I just installed a Whiteline RSB 2 weeks ago and I put the bushings on with one facing front and the other facing back. I tightened both sides up and then I noticed that the one facing front actually opened up instead of squeezing closed like the one facing back. So I took it off and turned it around and it closed up.
I didn't think it mattered since the bracket would clamp down on it, but it seemed I was proven wrong.
So I think that the rear bushings should have the split facing back.
Not sure about the front, but you can always try it one way and the other, that way if one is wrong, you only have to redo one.
