Replaced window regulator still need help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2009, 01:30 AM   #1 (permalink)
View blazdawgg's Photo Gallery
USA Replaced window regulator still need help!!
Hello All
I replaced my passenger rear power window regulator with a new one today all went well or so i thought. I finished up and later realized
the window goes down when i push up on the window button and up when i push down on the button. Not sure if its the motor or maybe i reversed the wiring clips? Any suggestions would be much appreciated am i am a newbie.
Thanks
Jerry
blazdawgg is offline   Reply With Quote
Old 09-27-2009, 01:41 AM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
you double check the connection?
Old 09-27-2009, 11:03 AM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Originally Posted by blazdawgg View Post
Hello All
Thanks
Jerry
I'd say you reversed the clip, but if I remember correctly, you can only put the clip in one direction. I would first check the clip, and if it is properly clipped in, simply reverse the 2 wires going to the motor (cut them and do a little switcharoo). You should be fine And btw
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 09-27-2009, 01:04 PM   #4 (permalink)
View lee777's Photo Gallery
How old is your vehicle? What was the original problem or symptoms with the window.
Assuming you have an exact replacement "regulator" (motor?), and the window still sometimes "acts up":
Frayed or broken flex cables can cause odd symptoms, often intermittent.
These run inside an accordion like rubbber boot inside the hinged part of your door.
The boot can be released from the door with some effort, be careful not to rip it.
Squeeze down the moulded part on the door and persuade it off.
Push the accordion ribs back to inspect the cables.
The problem may be with the driver door cable, from the master window control panel,
as it is usually subject to the most flexing and wear.
lee777 is offline   Reply With Quote
Old 09-28-2009, 10:52 AM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Did u buy it off eBay.
I know one of the guys that i bought it from reversed the wires. II have bought 3 off ebay and 1 of them was like that.
skewe is offline   Reply With Quote
Old 09-29-2009, 01:08 AM   #6 (permalink)
I did buy it off of ebay from car parts wholesale, so if the wire are reversed how would i fix that ?
Thanks
Jerry
Old 09-29-2009, 07:31 AM   #7 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
the clip can't be reversed, youre right. DON'T START RANDOMLY CUTTING WIRES PLEASE!
i'd say refer to page 88 in the body electrical PDF file...but i dont remember where the link is to them online. you'd be reversing pins 1 and 4 to correct the problem. make sure to disconnect the battery, use a multimeter to check everything, and solder all wires and heat shink/electrical tape them up right.
'07 Honda Ruckus Big Bore
Old 09-29-2009, 07:55 AM   #8 (permalink)
TN's Mad Chemist
It's not random if you know what your'e cutting but yes that typically is a bad idea... albeit there are only 2 wire going to the motor no?
1997 Acura RL-Gone
Old 09-29-2009, 08:09 AM   #9 (permalink)
Freakin Scooters
occasionally there's more than 2 wires going to the motor....but in this case it may just be 2. my point is, don't try it if you're unfamiliar with electrical work.
