Rear stabilizer bushings are hard to replace? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2009, 08:05 AM   #1 (permalink)
View Tcamry92's Photo Gallery
1992 Camry 147000 miles
The camry's are good but what I've noticed is that suspension parts break all the time. Now I have an issue with a clunking noise coming from the rear. Also a clunking noise from 58 to 65 mph. I believe it is the rear stabilizer bushings. According to this site http://autos.msn.com/research/vip/re...ta&model=Camry they break often on these cars.
Does anyone know if rear stabilizer bushings are hard to replace?
Tcamry92 is offline   Reply With Quote
Old 09-27-2009, 08:25 AM   #2 (permalink)
View whitefamily's Photo Gallery
They are quite easy but there are 2 diameters of sway bar out there. Take measurements first to make sure you get the right parts
Cheers
whitefamily is offline   Reply With Quote
Old 09-27-2009, 08:51 AM   #3 (permalink)
Are rear stabilizer bushings same as sway bar bushings? How would I measure it?
Old 09-27-2009, 10:25 AM   #4 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Stabilizer Bar = Sway Bar. Use a micrometer to measure the diameter of the bar.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-27-2009, 11:09 AM   #5 (permalink)
Thanks for everyone's help
Old 09-27-2009, 12:10 PM   #6 (permalink)
Slowly learning....
And to answer your question about difficulty: No, it's very easy. I'm 17 and I did it in about 45 minutes. Most of the time was spent getting the bolts off, they were rusted. Use penetrating oil.
Make sure you use jack stands to prop the car up, and block the front tires off.
Old 09-29-2009, 09:58 PM   #7 (permalink)
View xcmtb83's Photo Gallery
They are easy to replace if you can get the bolts to loosen without breaking the heads off. I dunno what it is about my Camry I always end up breaking a bolt or two off no matter how much penetrating oil I use. Use a wrench to find out the diameter of the sway bar. I believe it will be either 15mm 16mm or 17mm. That is how I determined the correct diameter when I replaced mine. Hopefully the noise will be gone after new bushings as struts are often the cause of the annoying clunk you may be refering to. Oh and it could also be the rear stabilizer links, I have replaced those also due to clunking and I am only at 94,000 on a 95. Best of luck and keep us up to date as to what the solution was.
xcmtb83 is offline   Reply With Quote
Old 10-08-2009, 04:58 PM   #8 (permalink)
while trying to replace the bushings I did snap the heads off. I had to take it to the shop, was charged 85 dollars for replacement of both. I'm still getting the same noise. Turns out it was not the sway bar bushings. Could it be the stabilizer links? Are those hard to replace or will the heads break off?
Old 10-08-2009, 06:35 PM   #9 (permalink)
RU2CHKN?
RU2CHKN's Avatar
Gameroom cash: $191865
View RU2CHKN's Photo Gallery
^replacing the sway bar links are pretty easy just use a hex key and hold the stud in place while you use I believe a 14 mm socket to break the nut loose. If the hex key hole is rusted and rounded beyond recognition, then use a pair of vice grips and clamp the stud while cranking on the nut with the socket wrench.
RU2CHKN is offline   Reply With Quote
Old 10-08-2009, 07:00 PM   #10 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
just wait until you need to replace the rear lateral control rods...those can be a pain in the butt!!!
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 10-08-2009, 11:00 PM   #11 (permalink)
If the vise grip technique fails you might have to resort to cutting off the nut with a dremel or similar tool or even using a drill to drill out the screw body. I had to drill mine out on the front and rear in order to replace the linkages. I started out with a 1/4" drill bit then went up to a 3/8" drill bit to complete the removal. The hex cavity (assuming these are the original parts, some aftermarket linkages do not have the hex cavity in them) that is on the end of the threaded section works nice to initially guide the 1/4" drill bit. If the nut begins to spin on you before you have the threads drill out all of the way put a 14mm box end wrench on it and continue drilling with the wrench end butted up against something solid. Oh, and keep the drill bit cool with any kind of spray lube or penetrating oil.
Old 11-27-2009, 07:10 PM   #12 (permalink)
After seeing around 5 mechanics that had no clue what the issue was and after replacing the rear stabilizer bushings and the struts which the mechanic said were the issue which was 700 total in repairs and around 4 months of driving less than 58 mph. It turns out it as a bad tire.
Old 11-27-2009, 10:45 PM   #13 (permalink)
View Kenny_McCormic's Photo Gallery
Depend on rather or not the last guy in there broke off a bolt and decided to weld on the bracket!
Kenny_McCormic is offline   Reply With Quote
