Thanks Justin and Mike.
Really appreciate your input!
Q: Is this an intermittent, or consistent issue ?
Consistent. When I hit the gas and it is in gear, it will crawl a few inches. I feel like I am ridding a FORD MODEL T and this is really puzzling. It is hard for me to get the car over 1000-1200 RPM even if it is in Neutral. Not sure if this is a RED Flag.
Q: Does it idle ok ?
Not really. It feels like the car is going through a seafoam cleansing. I have not done that in years and I don't plan to do so cos the last time I did it, my charcoal canister busted in my Gen4. Might be luck or just about time but no more seafoam for me.
It feels like the engine is short of air or sputtering.
Q: Have you checked for vacuum leaks ? (especially around the egr valve)
Not really. I looked and I do not see anything.
Q: Does it happen more often when Hot ? or Cold ?
Both
Q: Any running problem will eventually boil down to 1 of 3 things. Air, Fuel, or Spark.
Can't agree with you more. But what is causing it? I did the spark plugs and will look into the cylinder balance test.
I would do a cylinder balance test, to try and determine which cylinder is causing you the greef.
This is a simple test to do.
Let me know if you need help with this.
Q: Are the wires identical on the 2000 Camry? Can you switch them to the 93 as a test? If that checks out OK, I would next test the coil. For that test you will need a digital volt/ohmeter and the specs from any manual. Also inspect it visually for cracks.
No. Gen4 does not have an rotor and cap on the distributor.
I will try to borrow a volt meter or have somebody help me with it.
FYI: cylinder balance test
http://www.corral.net/tech/maintenan...t-balance.html
Reading over it, it would be hard to push it to 1k RPM as I am not able to get the engine up to that RPM
