Originally Posted by Eye8Pussies
oh...that plate...don't take the plate off....the seal comes out without removing that plate
Yep! Sort of answered my own question last night. After a bit of cleanup with brake cleaner and a rag, I looked it over closely. With the V6 there is a steel oil pan that has to come off, then the 'real' aluminum one has to come off, then that plate with the rear mail seal.
BUT ...
That retaining plate doesn't need to come off. I was freaking out over this seal, especially when a seasoned mechanic there told me "Unless it's leaking like crazy, don't replace it! It will just leak more with a new one becasue the old one is seated in and worn into place." I just could NOT see leaving that there when I was looking right at it with a new OEM seal in my hand.
Bottom line:
It was THE easiest seal I have ever done in my life. The old one popped right out with a small flat blade screwdriver and a bit of old bicycle inner tube as padding at the fulcrum point. Just jam it into the seal (destroying it), pad the shank against the crank, and pry. Two or three places and out it pops. The Hayes manual said getting the lip of new one over the crank was difficult because it's stiff, but I put a super thin layer of grease on the seal lip, the crank and the outside of the new seal. It then slipped right onto the crank, and I pressed it in pretty much with my fingers. A few taps with a rubber mallet and it was exactly where it needed to be.
