Removing steering rack advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2009, 11:00 PM   #1 (permalink)
View Silver99camry's Photo Gallery
4th Generation Removing steering rack advice
Hi,
I have 99 Camry 4 cyl and my inner tie rod ends are shot. I decided to go ahead and replace the whole rack with a new one. I found some instructions on this site for v6 and they suggest dropping subframe a bit. Is this required for 4 cyl as well?
Is engine attached to the subframe? I wonder if it can completely lowered with engine still in the car.
Thanks
99 Camry 2.2L
Silver99camry is offline   Reply With Quote
Old 09-28-2009, 11:32 PM   #2 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
yes you do have to lower the back a bit. it helps to loosen but not remove the front bolts. don't have to disconnect motor, but for safety's sake, put some sort of support under it.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 09-28-2009, 11:53 PM   #3 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
Been there, done that.
Steering bellow boot torn, major fluid leak
Juicy stuff is on page two.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
