+1. I use a bench bleeder kit. Basically your fingers will act like one-way valves. If there is pressurized air/fluid they'll push your fingers aside to exit the master cylinder. When there is no pressure (released pedal), then your fingers closed the ports like one-way valves close the ports.
You may also want to raised the rear of the car so the master cylinder is about level. You should be able to tell easily if there is air in there then.
I never tried this, but when the master cylinder is level, you may be able to see bubbles in the reservoir if the piston is pushed back. It's like a reverse flush, and I assume you have lines with only clean fluid by now. Might be worth a try before you remove the brake lines using flare nut wrenches.
Do you have ABS?
Originally Posted by Dave's
Never actually had to bleed a master cylinder but I think you would keep your fingers on. The person pressing the pedal should have no trouble overcoming the pressure of your fingers and forcing fluid and air past them. Think of your finger as a one way valve. As the pressure from the pedal diminishes your finger(s) immediately close off air from re-entering.
