lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2009, 07:48 AM   #1 (permalink)
Gameroom cash: $325545
View adalex's Photo Gallery
4th Generation lights
I was looking at my keyhole on my 99 camry and noticed it has a clear ring around the ignition. Is that supposed to light up at night? if so could anybody tell me how to remove some of the panels to get the bulb? as far as I know if it used to light up its been burnt out for atleast 4 years. thanks
adalex is offline   Reply With Quote
Old 09-30-2009, 08:04 AM   #2 (permalink)
View FireFire's Photo Gallery
It will be off after couple seconds(maybe 1 mins). Don't worry about that.
FireFire is offline   Reply With Quote
Old 09-30-2009, 08:07 AM   #3 (permalink)
No, I mean is it supposed to light up at all? Because it doesnt
Old 09-30-2009, 11:18 AM   #4 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
Yes it is suppose to light up. If you take that small panel off and unplug a few things you can take the light bulb out and replace it with a new bulb. But before you take the smaller panel off you need to pop off the bigger panel under the steering column.
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 09-30-2009, 11:23 AM   #5 (permalink)
View skuttduck's Photo Gallery
My 2000 has the original bulb in there, and it lights up when I open the door. Its nice so you can find the ignition in the dark.
skuttduck is offline   Reply With Quote
Old 09-30-2009, 01:24 PM   #6 (permalink)
View .Camryman97.'s Photo Gallery
id just leave it
too much work for one small bulb imo
97 Camry: 17" Enkei rims, lowered with Ground Control and tokico,
Alpine head, mids, and highs, rockford 4-channel, 12" P3 rockford,
MTX monoblock, TRD RSB, Clear Corners, 6K Mod Express HID kit
.Camryman97. is offline   Reply With Quote
Old 09-30-2009, 02:27 PM   #7 (permalink)
'_'
Touge Star
'_''s Avatar
Gameroom cash: $421512
iTrader Score: 10 reviews
View '_''s Photo Gallery
My friend changed the bulb for me in a matter of minutes. It lights up when you open the door and when you unlock the car with keyless entry I think.
山道だいすきです。
http://www.cardomain.com/ride/2538603
'_' is offline   Reply With Quote
Old 09-30-2009, 03:14 PM   #8 (permalink)
Camry: 94-I4 and 94-V6
View sintox's Photo Gallery
I have Camry 94 L4 LE.
That keyring lights up when open the door. The problem is it turns off too fast, only last maybe 6 sec. My apartment garage is not well lit so I wonder if I can increase the duration of the light at all.
sintox is offline   Reply With Quote
Old 09-30-2009, 04:57 PM   #9 (permalink)
4th Generation
i figured that, but how do u get to it?
Old 09-30-2009, 05:11 PM   #10 (permalink)
YOu need to take off 2 plastic panels above your legs and above your knees.
You need a smallish flat screwdriver. You'll see small plastic cover the size of a coin just above your knees. pry off, then remove the 10mm bolts. There are 4 of them, plus 4 more with a philips-screw driver. Then remove the coin-holder by pressing both side with your index and thumb, then remove the screws. In summary, you need a portable flash light to see them.
Finally, you can access the plastic cover near the keyring.
PS: you can still drive around with the panels off.
But when disconnecting wires, be safe: disconnect the battery 'coz of the airbag.
