1mz engine removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2009, 06:56 PM   #1 (permalink)
View sandeeevil's Photo Gallery
1mz engine removal
What points do I use to remove 1mz motor from my sandrail. What is the best points to lift with a cherry picker?
sandeeevil is offline   Reply With Quote
Old 09-30-2009, 08:47 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
there a lift hook on the back side of the intake and a i guess you and use the front mount to hook on to a well
^ and leaving it that way!
Old 10-01-2009, 01:59 AM   #3 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
after you have everything disconnected properly... there are two hooks... at least there should be... there should be a black rounded hook in the front...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 10-01-2009, 11:38 AM   #4 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
newer 1mz's don't have the hooks. there's a few beefy threaded holes where the hook/hanger would be on the front cylinder head (on the side pointed away from the direction the upper intake plenum points), and i believe there are some matching ones on the other cyl head as well. it's probably a good idea to use BOTH of these holes with your own hook bolted in rather than just sticking a bolt in it with a piece of chain on it.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-01-2009, 07:13 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
the more you can spread out the force due to engine weight the better....
Dave Zoni
Old 10-02-2009, 10:43 AM   #6 (permalink)
Canyon Killer
View ekopel's Photo Gallery
hey bud,
So i didn't have hooks...ive pulled and installed the motor like 4 times in my car never having a problem. i used (most of the time) the two allen head bolts on the lower to upper intake plenum as well as the two 14mm (i believe) bolts that go with it. in total, there are 4 bolts that bolt the upper and lower intake together. i used all of them, with no problems. The engine (without the tranny) probably only weighs about 300 lbs. Me and my buddy actually dead lifted it and carried it down 2 stairs lol. otherwise, you can use the torque strut mount and put a engine to tranny bolt in there just to get it situated, then use pump-style car jack to hold the engine in place and get all the holes lined up. the engine is light since it is an aluminum block, so you should be fine with the method i used. just make sure that it dissipates the force as much as possible. I also had a load leveler which helped - a lot. hope that helps!
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 10-02-2009, 09:21 PM   #7 (permalink)
View US Route 6's Photo Gallery
I just finished a swap yesterday, and I used one of those yellow lift straps. I hooked one end to the rear lift hook, ran the strap through the hoist's hook, then the other end down and around the front exhaust manifold, and hooked the loop to the hoist hook. Worked very well. Sorry I didn't think to shoot some pics.
US Route 6 is offline   Reply With Quote
