Quite a funny situation... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2009, 07:13 PM   #1 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
3rd Generation Quite a funny situation...
Ok I haven't drive the Cam in a week due to bent wheels so it just sat in the yard with the alarm not armed but the doors were locked. I decided to take it for a little spin one day and I manually unlocked the door through the lock cylinder to open the door instead of using the remote. Dome and door lights came on ok went to turn it on I didn't didn't get anything and there was still some power to it. Tried it again... didn't work the second time on the third time I tried it I always had a problem with the rear driver side window not working. Well that day I never did get it to turn but when I had it on ACC the window started working
I don't know what caused the power drain but I did jump it off and the car back on at the end of the day the window stopped working??? I'm not worried about the battery being almost dead I just wanna know what would make the window stop working when I got full power back and another thing is what would cause the battery to go dead if the alarm wasn't armed I mean would it still be active? Oh yeah I have the Python 871XP unit if that helps.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 09-30-2009, 07:41 PM   #2 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Could be as simple as you not closing a door all the way, or a sensor switch stuck in the "open" position keeping one of the dome lights on, or possibly even the glove compartment.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 09-30-2009, 10:47 PM   #3 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Originally Posted by JayMax03 View Post
...what would cause the battery to go dead if the alarm wasn't armed I mean would it still be active? Oh yeah I have the Python 871XP unit if that helps.
Do you have a stereo? You do!? There you go...it has to draw power directly from the battery for it's memory. Factory stereo or not, it will drain the battery dead if you let the car sit long enough.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
Old 10-01-2009, 11:16 AM   #4 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
^^ true but unless the battery is on its last legs, a *properly connected* stereo won't drain a battery in just one week. not even a month.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-01-2009, 12:09 PM   #5 (permalink)
JayMax03's Avatar
well the radio would explain why the battery almost dying, but could anyone explain the situation about the window or is that just one of those days... I know it couldn't be the window regulator now if some power was going through it
Old 10-01-2009, 12:12 PM   #6 (permalink)
Gibson99's Avatar
could just be a fluke. window motor could be overheating itself after very limited use which is how most motors fail. since you hadn't used the motor in forever, it wasn't hot, and when you use it, it got hot and locked up again.
i say once you get the battery drain problem cured, replace that window motor.
98 Camry CE v6 5s
97 MX-5
www.gibson99.com
Old 10-01-2009, 01:04 PM   #7 (permalink)
JayMax03's Avatar
so i should try to replace the regulator... what if I get the same reaction could there be some other solution if the regulator wasn't the problem?
Old 10-01-2009, 01:34 PM   #8 (permalink)
Gibson99's Avatar
the regulator is NOT the same thing as the motor, though sometimes they are sold as a set. the regulator is the actual gears/track/cable unit that directly attaches to the glass. the motor is just that - only the motor and a gear to turn part of the regulator.
98 Camry CE v6 5s
97 MX-5
www.gibson99.com
Old 10-02-2009, 11:25 AM   #9 (permalink)
JayMax03's Avatar
well it happened again last night this time I did notice some blinking when I turn on the HU the window started working I'm going to still check it out anyway to see if the motor is overheating hopefully that won't be the issue
