Why won't my 92 camry start? Please help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2009, 07:46 PM   #1 (permalink)
View jmeone's Photo Gallery
I have a 92 Camry 4cyl it shut off and would not start just kept cranking. We towed it home, fuel pump is good, timing belt is moving when cranking, no spark and the fans ran non stop when the key was off until the battery went dead. I changed the coil and it started. Drove it a few miles and it died again. Changed the main engine relay today still no start, but the fans finally shut off. Whats the deal? Any help is greatly appreciated.
jmeone is offline   Reply With Quote
Old 09-30-2009, 07:52 PM   #2 (permalink)
Gameroom cash: $137274
View johnfrisco's Photo Gallery
Sounds like the timing is off. When did u last replace the timing belt?
johnfrisco is offline   Reply With Quote
Old 09-30-2009, 08:15 PM   #3 (permalink)
The belt has about 40,000 miles on it the car has 118,000
Old 09-30-2009, 08:45 PM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
throwing and codes? cap, wires and coils fine? when was the fuel filter last replaced?
^ and leaving it that way!
Old 09-30-2009, 08:48 PM   #5 (permalink)
I changed the cap and rotor when I changed the coil It could use a fuel filter, but that wouldn't explain no spark.
Old 09-30-2009, 09:57 PM   #6 (permalink)
View HappyHarv's Photo Gallery
3rd Generation check the igniter
Something similar to this happened to me many years ago when my '92 had about 140,000. It ended up being the igniter. No spark makes me believe this might be at least a part of the problem.
HappyHarv
HappyHarv is offline   Reply With Quote
Old 09-30-2009, 10:22 PM   #7 (permalink)
View Novice_cardude's Photo Gallery
Harv knows that of which he speaks...
The fans not shutting off would make me take a second look at the ignition circuits though. Could be some electrical gremlins running around in there.
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
Novice_cardude is offline   Reply With Quote
Old 10-01-2009, 06:47 AM   #8 (permalink)
Is there any way to test the igniter? Cause the cheapest one I found was $185.
