Rear Sway Bar Bushings? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2009, 02:05 PM   #1 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568401
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I'll make this short. The car is a '95 V6 LE with 214,000 miles. Struts where changed about 35,000 miles ago. I'm hearing a slight clunking/thumping(very low) noise from the rear passenger side wheel. It doesn't happen all the time. It doesn't sound like it's a strut that's gone bad, I know very well what that sounds like. Upon further investigation, it seems to be coming from near the wheel itself, not up top where the strut is. When I jack the car up and pry at the wheel at 9 and 3 o'clock, I hear a faint creaking noise. I also checked the exhaust system, more specifically the muffler, for any excessive play(i thought it might be simply that since the muffler is right behind that wheel) and found none. Based on the what I was able to find in a search on TN, I'm thinking it's the sway bar bushings. Anyone have any opinions or alternate diagnosis? Any specific brand I should buy? Since it's getting cold around here and I've never changed bushings before, how much should I expect to pay labor (roughly)? I'm also asuming I need an alignment afterwards? Thanks in advance for the help!
1jGuu
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 10-01-2009, 02:33 PM   #2 (permalink)
Camry Expert/MR2 JR Xpert
jtex2717's Avatar
Gameroom cash: $272115
View jtex2717's Photo Gallery
The bushings is exactly what its sounds like.......if you are familiar with hand tools or have some yourself.......I would highly suggest u save your money and do it yourself. Go get some Moog bushings, (THEY ARE BLUE) then..... All you do is take the wheel off, look for the bushings and unbolt the one bolt holding the bracket on. Remove the old bushing. Get some light greese and lube the inside of the new bushing, slide it on, then bolt it back into place......Boom Done......30 min tops if u have never done this from start to finish......
Finally Red MKII MR2 5s & Metallic Blue 96 Cam 1MZ
Watch out for the build thread!!!
IM BAAAAAACK!!!!!!!
jtex2717 is offline   Reply With Quote
Old 10-01-2009, 02:53 PM   #3 (permalink)
Slowly learning....
View Retrospekt's Photo Gallery
Jack the car up again, slide under and shake the sway bar up and down. If you hear it clunking or see it moving inside the bushing, they're bad.
If you don't want to wait for shipping, you can get bushings from your local Napa auto parts. I recently used those, they look to be pretty good quality.
1996 Toyota Camry | 4 Cyl. 2.2L | Black Paint with Tan Interior | All Stock | DEAD at 155k. Broken Crankshaft/Main Bearing
Retrospekt is offline   Reply With Quote
Old 10-01-2009, 03:39 PM   #4 (permalink)
TN's Mad Chemist
Well, if you say it's a matter of one bolt, then I'll attempt it. I have the tools. I guess it can't be more comlicated then some of the things I've done before... I was just worried that it was more involved than that. I called up my local O'Reilly's and they have some MOOG bushings for 15.99$, which seems very resonable! I can get them by tommorow morning. But the guy I talked to mentionned that they offer then in 15/16mm or 17mm. How do I know which size is in my car?My car's frame is an MCV10 frame if that helps...
I'll give that a shot, thanks for the advice! Did you have to align the tires after changing the bushings?
1997 Acura RL-Gone
Old 10-01-2009, 03:57 PM   #5 (permalink)
Slowly learning....
I did my bushings the day before I went to get new tires and allignment.
New rear sway bushings shouldn't mess with your allignment though.
Old 10-01-2009, 06:38 PM   #6 (permalink)
TN's Mad Chemist
That's conforting I was worried that because of 16$ bushings I would have to get a 50$ alignment As for the bushing size, I solved the problem by ordering both, and o'reilly's told me I can simply return the one that doesn't fit Is there a specific torque value for any of the bolts I'll be taking off? I wouldn't want to leave it a tad bit loose and have my suspension fall apart mid freeway or something...
1997 Acura RL-Gone
Old 10-11-2009, 10:08 PM   #7 (permalink)
TN's Mad Chemist
I realized I forgot to update this thread! Well, I took things apart and the bushing had indeed shrunk, obviously enought to cause play in the swaybar. All expected. Taking this apart was easy, it was putting things back together that was a real b**ch. I could not get the 2 bolts for the bushing bracket to line up, no matter how hard I tried pusing the sway bar up. I ended up having to dremel off the screw attaching the sway bar to the endlink (which was probably neccessary from the beginning), and by that very token, ruining my endlinks For the record, the sway bar diameter for the V6 is 15mm. At the end of the day, my rear end is noise free Thanks for the help guys!!
1997 Acura RL-Gone
Old 10-11-2009, 11:03 PM   #8 (permalink)
whip_cracker's Avatar
View whip_cracker's Photo Gallery
I must say...
If there's a sports version of the Camry there, the size would more likely be 17mm size. I have the Touring Series Camry here and that's what size the swaybars are.
Good on ya for doing it yourself mate
whip_cracker is offline   Reply With Quote
Old 10-12-2009, 07:53 AM   #9 (permalink)
TN's Mad Chemist
Originally Posted by whip_cracker View Post
I must say...
I can honestly say that I'm surprised it turned out to be 15mm. When I was at the parts store they had 15mm or 17mm listed for my car so I bought both. I was thinking that maybe the I4 had the 15mm bushings, but I guess not Now the I4 guys have something to be happy about, they have bigger sway bars than on the V6's
Thanks All in all, it wasn't as bad as I was expecting, despite me having to replace the endlinks along with the bushings. Thank jtex2717, I tackled this myself upon his encouragment But I must admit, it always feels good to do things yourself. Not only do you know it was done right, but who else will take the same care with your car as yourself, right?
1997 Acura RL-Gone
