Could someone help troubleshoot? kinda urgent - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2009, 01:07 AM   #1 (permalink)
View felpz123's Photo Gallery
211k(miles) 94 camry le 4cyl
ive been driving around the highway for a couple hours, then all of the sudden i felt like i hit something big on the road(but now that i look back on it i guess it was the transmission or something bucking). that was it, for about 20 minutes until it did it again, and then the engine light + oil light came on, i then stopped on the side of the road as fast as i could.
i then tried to start the motor and it sounded funny so i turned it off.. my dad later arrived and we started it, then funny noise of the engine stopped a couple seconds after it was running, we then put it in gear(automatic), and throttled it, but it acted like it was in neutral, in all gears.(1, 2, d and reverse).
checked the transmission fluid and oil and they both looked fine.. no visible damage that i could tell on the engine.
trying to get this figured out tonight so i can decide on whether to tow it to the shop or my house, depending on the price.
thanks for any help
(have had problems with starting up in the past, dying a couple seconds after starting it up, could be unrelated but i thought id add it)
felpz123 is offline   Reply With Quote
Old 10-03-2009, 01:15 AM   #2 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation
Unfortunately sounds like the auto is slipping. Might have seen its last day..
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 10-03-2009, 01:28 AM   #3 (permalink)
ugh.. why did it go so quick?
Old 10-03-2009, 01:31 AM   #4 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
how many miles are on it?
ACCIDENT...
Thanks
Old 10-03-2009, 02:16 AM   #5 (permalink)
211,000miles
and by quick i mean like without much warning
Old 10-03-2009, 12:57 PM   #6 (permalink)
if anyone who has replaced their transmission/rebuilt it could tell me what i can expect to pay at a shop?
Old 10-04-2009, 03:29 PM   #7 (permalink)
http://littlerock.craigslist.org/cto/1402771355.html
what do you guys think of that camry? it would be a helluva lot cheaper than a new tranny
Old 10-05-2009, 07:53 AM   #8 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
drop the transmission pan to see if there are any parts in there. you can try to change the fluid to see if that does anything (though a long shot).
to rebuilt an FWD transmission on my previous car (1993 grand am) set me back about $1300 just for reference.
Old 10-05-2009, 08:35 AM   #9 (permalink)
View Camry LE 94's Photo Gallery
3rd Generation
Not too sure about what the problem is but I paid $1600 for an overdrive replacement.
1996 Toyota Camry DX [230K]
DEPO Chrome HL's w/ converted Nokya Arctic White 9005 low beams, CF Dash Kit, 14" AR Rims
Advanced Camry DIY'er Noob
Camry LE 94 is offline   Reply With Quote
Old 10-06-2009, 01:39 PM   #10 (permalink)
thanks for the help guys
just got back from the mechanic and he said the differential was screwed.. transmission would also have to be replaced, he quoted $900.
going to go look at this one tomorrow http://littlerock.craigslist.org/cto/1402771355.html, whatdya think? would it be easier replacing the airbag or the entire steering wheel?
Old 10-07-2009, 09:57 AM   #11 (permalink)
View hooRAH's Photo Gallery
I think your best bet would be to swap out the transmission and differential with a used one from a JY and call it a day. The job isn't terribly complicated and you don't have so many unknowns.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 10-07-2009, 10:11 AM   #12 (permalink)
Canyon Killer
View ekopel's Photo Gallery
felpz! hold on!!!! I had the same symptoms about two years ago (about 20,000 miles). Try changing to a heavier weight ATF fluid. Or use an additive. I would definitely suggest taking a look for parts or metal in your ATF fluid. If that is the case, this may not work. If it is not the case then give this a try. Its worked for 2 years for me, maybe it will work for you! Worth a shot at least
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
ekopel is offline   Reply With Quote
Old 10-07-2009, 06:57 PM   #13 (permalink)
i dont know if you read my previous post but i took it to a mechanic and he said it was the differential.. he then proceeded to show me the tires in drive would barely turn at all, so i think this is mechanical and not fluid related. but i'll call him up tomorrow and see what he says. thanks for the input.
i have 0 experience with mechanics, but my dad does, what kind of equipment is necessary for a swap? also could i get the website for JY so i can check out how much it costs.
Old 10-07-2009, 08:03 PM   #14 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The $900 tranny is probably a salvage. Might want to ask how many miles and what kind of warranty. For an older car that's probably the quickest way back to the road.
I'd drop the pan on the newer one and change out the strainer as well. An ATF kit is about $15 (Fram) and Walmart 1gal Dexron II/III-compatible ATF is about <$10. Change the differential too, same ATF so get 2 gals.
Old 10-07-2009, 08:08 PM   #15 (permalink)
Not sure about the differential call.
If the car isn't moving and the problem is only within the differential (spider, pinions, etc) why would things sound funny?? Differential isn't moving at all right?
I would wonder about the torque converter and ATF pump. Maybe whatever clutches engaged at the time (such as OD).
But in any case it's a "new" (rebuilt or salvaged) tranny.
