Originally Posted by muminiasty
will toyota dealer have those drain plugs?
Toyota dealers
should have the drain plugs, call and ask to make sure they have it before going to buy it.
would it be better idea to unscrew whole fluid pan and drain it slowly that way. replace the gasket and not touch drain plug?
My dad has a 92 GMC Sonoma with a tranny pan
without a drain plug so the only way to drain it is to take the pan off. I'll tell you it is one
messy job. I didn't have an oil pan bigger than the fluid pan to catch the fluid so it just got more messy. I've done it twice and it didn't get any easier the 2nd time.
You can do it this way, but it turns an easy drain/refill job into a more difficult job. Draining the fluid before taking off the pan makes it
so much easier when you take the pan off for cleaning or change filter.
IMO it's not worth the hassle over the cost of a new drain bolt.
