Cruse Control - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2009, 01:26 PM   #1 (permalink)
View cave man's Photo Gallery
Cruse Control
On a 98 4cyl. Turn on the switch and the Cruse light on the dash comes on. Press it down to set the speed the light on the dash flashes and you can hear a relay under the dash but the cruse will not set. Fuse is good and the speedoneter is working.
cave man is offline   Reply With Quote
Old 10-05-2009, 03:16 PM   #2 (permalink)
Any Ideas?
Old 10-05-2009, 04:01 PM   #3 (permalink)
A stock Camry? Blasphemy!
Gibson99's Avatar
View Gibson99's Photo Gallery
stickshift or auto? check connections at cruise module under hood (next to battery), and at clutch and brake switches (as applicable). cruise ecu is located on the brake pedal bracket, check its connection as well.
can also follow proceedure in shop manual to put cruise into diag mode. short 2 pins in the little diagnostics box near passenger fender, and count how many times teh cruise light blinks.
98 Camry CE v6 5s
97 MX-5
95 Camry SE v6 2dr SC (sold)
www.gibson99.com
Gibson99 is offline   Reply With Quote
Old 10-05-2009, 05:21 PM   #4 (permalink)
Thanks I will look at the connections tonight.
